70% Hwy, 20% street, 10% Rock Climbing - Digressive or Progressive
Discussion in 'Suspension' started by iJDub, May 29, 2013.
  1. May 29, 2013 at 11:28 PM
    iJDub
    iJDub [OP] Well-Known Member
    What will suit me better? Digressive or progressive shocks if I do a lot of highway, a bit of city and a smaller bit of rock climbing.
    I was going to get the Icons but they charge extra for 700lb springs so I was then thinking Kings...please help.
  2. May 30, 2013 at 11:19 AM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
    I think digressive is the way to go but need a good bump stop if you hit them often. They slam them hard due to nature of the valving.
  3. May 31, 2013 at 8:46 PM
    iJDub
    Will I be hitting them at high or low speeds?
  4. May 31, 2013 at 9:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Progressive is probably better in all the instances you list.
  5. Jun 1, 2013 at 9:35 PM
    iJDub
    Chris, can you explain to me a bit please? Thanks.
  6. Jun 1, 2013 at 9:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A progressive is going to be softer on the smaller pumps, and stiffen up on the faster, larger bumps, whereas a digressive is opposite. A progressive suspension gives a softer street ride, but protects from falling off ledges, or rocks by stiffening up the last half (or so) of the travel.
  7. Jun 1, 2013 at 9:57 PM
    iJDub
    And when I'm driving on the FWY, is it going to be too stiff?
  8. Jun 3, 2013 at 10:58 AM
    iJDub
    Someone chime in?
  9. Jun 3, 2013 at 11:02 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Nope, street driving will be near stock for both pro and digressive valving, digressive valving will be softer if you hit a speed bump at speed, progressive will be softer slower.
  10. Jun 3, 2013 at 11:15 AM
    iJDub
    Last question: For rock crawling, would having a digressive shock be a disadvantage?
  11. Jun 3, 2013 at 11:38 AM
    disc0monkey
    numbers of posts in the past three years say yes. although it seems like ICON is currently working on changing that perception.
  12. Jun 3, 2013 at 11:46 AM
    iJDub
    The disadvantage would be that the ride is harsher as you crawl over the rocks?
  13. Jun 3, 2013 at 11:56 AM
    disc0monkey
    i think it won't flex as easy on smaller slower rocks. the flip side is if you're crawling and hit a big rock it will flex better then progressive.
    Even if you're driving at a slow pace you can achieve fast shaft speed on the shock by hitting a big rock and it will absorb it better then progressive.
  14. Jun 5, 2013 at 9:50 AM
    iJDub
    What about not wanting to slow down for speed bumps :)
