7000lb pull
Discussion in 'Towing' started by chevyray13, Aug 21, 2019.
  1. Aug 23, 2019 at 6:20 AM
    Super Guest
    Super Guest Active Member
    Adam
    2019 Tacoma TRD Sport
    It is somewhat surprising how little regulation/oversight there is in towing trailers. I always thought once you were over like 24k or something you needed a CDL? Technically, couldn't you go buy yourself one of those 1ton dually trucks that can tow like 35,000 pounds, and then go pick up a nice 20,000 pound 5th wheel and one is going to say anything or ask if you know what you're doing
  2. Aug 23, 2019 at 8:12 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    Many states require a NON CDL Class A license for pulling anything over 16k gross (combined weight truck and towed load) others it’s higher. Some not at all.
    26000lb+ is usually the CDL requirement
    Then there is the whole weighted tag for road use tax
    Basic tag weight limit (4000lb) a Tacoma is on fringe of max weight and over weight with driver.
    To legally tow a lawn mower or even have one in the bed I need a weighted tag. (8000lb) anything more and I could get pulled and fined. I could buy a higher weight, but I’ll likely never need. And it’s not required for RV type trailers.
    My 4Runner I could legally pull up to 26k and nothing would be said. (Would never happen)
    It’s the state to state regs that make things weird
  3. Aug 23, 2019 at 9:48 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    My $0.02: Why potentially overheat the transmission or spin a clutch when you can rent a Uhaul and have that take to abuse?
