700lb coil really necessary?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by @old.man.adventures, Feb 21, 2018.
  1. Feb 21, 2018 at 12:00 AM
    @old.man.adventures
    @old.man.adventures [OP] Well-Known Member
    2015 DCSB
    Icon Stage 4 Delta Joint
    I have Icon stage 4 coilovers stock 650lb coils. Boy these puppies ride stiff. I can stand on the front and it would barely move. My question is are there people out there that have added a steel bumper to the front and kept the 650lb coils? Is it adequate? The suspension hardly moves at all to begin with, I feel every damn crack and pebble on the road and I'm thinking the added weight will help it cycle a bit more.
  2. Feb 21, 2018 at 9:10 AM
    badger
    badger Well-Known Member
    07 SR5
    I prefer 650 with a bumper and winch.
  3. Feb 21, 2018 at 9:12 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I have a steel plate bumper with no winch in the front on 600 lb coils and it still rides like a dream.
  4. Feb 21, 2018 at 9:24 AM
    badger
    07 SR5
    Ideally, the spring you choose should let your suspension move through it's entire range in the circumstances that you drive. If you race at 100 MPH down rutted roads, you will need much higher spring and dampening rates than the exact same truck driven at slow speeds. The non-race offroad market has almost always pushed spring rates too high for good compliance at the speeds we typically drive. There has been this pervasive view that stiffer is somehow tougher, or something. It isn't. It just over stresses other components, compromises control in many circumstances, and ruins your kidneys. For some people, 700 may be perfect. For me 650 better fulfills the requirement I described. Experimentation is the only way to really know.
  5. Feb 21, 2018 at 9:28 AM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    This is also dependent upon preload
  6. Feb 21, 2018 at 9:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Always keep in mind that the spring rate is per inch of travel.
    IE the ones you have now require 650# to compress one inch.
    DoorDing and ChadsPride like this.
  7. Feb 21, 2018 at 9:34 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    What about getting them re valved?
    ChadsPride likes this.
  8. Feb 21, 2018 at 9:43 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Sounds like you may have them pre-loaded too much and you've lost all droop. How high is it lifted?
  9. Feb 21, 2018 at 9:54 AM
    badger
    07 SR5
    revalving only affects dampening, not spring rate.
    DoorDing likes this.
  10. Feb 21, 2018 at 9:56 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have 700lb and with just a Bumper it rode perfect
    Sje1124 likes this.
  11. Feb 21, 2018 at 9:59 AM
    doorsidedown
    doorsidedown Well-Known Member
    I have 650lb and I’m adding an arb bumper this week (no winch) My guess is I’ll make the jump to 700, but I’m going to try what I’ve got first. The OME springs meant to be paired with the ARB are 660lb so we’ll see... will report back if you remind me OP.
  12. Feb 21, 2018 at 10:34 AM
    mtmudrunner
    mtmudrunner Well-Known Member
    Wes
    Tomcreek corner, MT
    1985 Toyota 4x4 p/u
    Rust
    I just installed an arb and 10k winch with synthetic line yesterday, I am hoping my ome kit gets here this week and I can get it installed this weekend ordered 886 coils with 1/4" spacers and 9000 shocks, hd rear leafs I'll let you know how it sits and rides.:cheers:
  13. Feb 21, 2018 at 2:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Seems like the issue is more than just the spring, either preload or stiff shocks. I have 650lb coils with the OEM TRD Baja setup and it rides amazing on the street. Doesn’t feel stiff. Only extra weight on the front is the supercharger. It does feel a bit stiff for low speed off road though.
  14. Feb 21, 2018 at 6:17 PM
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    What does your bumper weigh, and how much did it drop the front end?
    doorsidedown likes this.
  15. Feb 21, 2018 at 6:39 PM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think it’s around 120 lbs give or take, maybe a little lighter. I barely noticed a difference in ride hight, maybe .5-.75” down. I still have barely any preload, with the bed unloaded I have the tiniest amount of rake still.
    Pigpen and sioux[QUOTED] like this.
  16. Feb 22, 2018 at 3:03 AM
    @old.man.adventures
    2015 DCSB
    I only have about a 2" lift in the front. I didn't adjust the coilovers other than the driver side a little to accommodate lean. It's just really stiff....I cant compress the front hardly at all with my body weight bouncing on it. The rear flexes much easier with the progressive AAL
  17. Feb 22, 2018 at 9:45 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I have 620# springs I believe with a plate bumper and it feels good
  18. Feb 22, 2018 at 10:03 AM
    Pigpen
    Dan
    Northwest Montana
    The real issue is this:
    You put in coilovers meant to be paired with armor you don't have. It's going to ride rough. Add armor or change your suspension.
    badger, DoorDing and MolonLabeTaco like this.
  19. Feb 22, 2018 at 10:11 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    What he said!
  20. Feb 23, 2018 at 1:19 AM
    @old.man.adventures
    2015 DCSB
    So you are saying that if you get coilovers that they are "meant" to be paired with armor? Yeah I don't think so. The Icon 650lb coils are their standard coils for trucks without additional weight like bumpers or winches. They offer a 700lb coil option for those who plan to carry that kind of additional weight.
