700lb Springs for Plate Bumper/Winch?
Discussion in 'Suspension' started by iJDub, May 28, 2013.
  1. May 28, 2013 at 5:51 PM
    iJDub
    iJDub [OP] Well-Known Member
    What's a good spring rate if I will be putting an All Pro front bumper and winch on there?
  2. May 28, 2013 at 5:53 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    1st or 2nd gen?
  3. May 28, 2013 at 6:12 PM
    iJDub
    2nd double cab 4x4
  4. May 28, 2013 at 11:47 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Any plans for skidplate at all in your future? Synthetic or steel winch cable?
  5. May 28, 2013 at 11:51 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    nofords08 runs similar setup (- winch) and uses 700#
  6. May 28, 2013 at 11:56 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    I have 700# Kings, and got them before my bumper, winch, lights, and skids. My pre-load was almost nothing, but I've since changed that as I added more to the front. Mine rides great! Always did, actually - it never seemed stiff to me, like I heard it might without the weight.
    EDIT: Like Will asked, I got the synthetic line to shave off some weight.
  7. May 29, 2013 at 12:37 AM
    iJDub
    Probably skids in the future...and sliders and rear bumper...probably synt line.
    Looks like I'll get a 700lb spring. Thanks
  8. May 29, 2013 at 3:58 AM
    penguins_cc
    Will
    Bellevue, WA
    Good choice, OP. I have 700lb springs with bumper, winch (synthetic line), sliders and skids. Never once regretted the choice. Rides great without loading the springs down.
  9. May 29, 2013 at 10:34 AM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    Nice! I like this thread. I was thinking of going to some 700lbs springs. I am running OME 886's (which are a 656lbs spring) and they don't quite seem to cut it.
  10. May 29, 2013 at 1:16 PM
    knotty
    knotty Well-Known Member
    milwaukie, oregon
    what coil springs are you running ?
  11. May 29, 2013 at 1:28 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Me? OME 886's.
  12. May 29, 2013 at 1:35 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
  13. May 29, 2013 at 1:36 PM
    CanisLupus
    CanisLupus Well-Known Member
    Ashburn | VA
    '11 DCSB 4WD / '13 Ninja 300 / '04 CRF 150F
    What King's or Icon's do people run? I get confused looking at all the options on websites. I am looking to add a winch (synthetic line) and skids at some point (I already have a front plate bumper) and I want to upgrade my coilovers. I would like to get a almost level stance (slight rake) with Dakar's in the rear.
    Do I want the 2.0 or 2.5 option? What do those mean? And do you get to select which pound coil you want when ordering these or do they usually come with 700# coils?
  14. May 29, 2013 at 1:38 PM
    SoCaltaco65
    go with the 700#
  15. May 29, 2013 at 2:19 PM
    carcharias
    Los Angeles, CA
    '11 AC MGM OR
    Matt, here's what little I know:
    The 2.0 vs 2.5 is the diameter of the shock. Larger shock = better ride, more $, and maybe a fit issue (not sure about that last one, though).
    Yes, you do get to select what # coil, but I believe Icon charges for the 700# (unlike King).
    Call DSM and they'll walk you through putting a package together. There's no "set" King shock - I had to measure hole-to-hole in the rear so that they could build it correctly at the factory. I also have Dakars, and they're awesome!
    Hope this helps a bit.
    Aaaaaand, this:
  16. May 29, 2013 at 4:14 PM
    CanisLupus
    Ashburn | VA
    Thanks a bunch for the info Mike.
    I see the "Build your own Mid-Travel" choice on the DSM sight, but it seems that you are required to choose a UCA when ordering. I want LR UCA's (heard negative things about uniball UCA's? and dirt/grime maybe?) but they don't have them listed. Are LR UCA's not able to be paired with Icon's / Fox's?
    I am planning on just getting the Bilstein 5100's for 3''-4'' of lift or OME N182 instead of Icon's or King's in the rear although.
  17. May 30, 2013 at 4:42 PM
    penguins_cc
    Will
    Bellevue, WA
    I was wondering where you got that exact spring rate, but did some research and saw 886s rated at 115 N/mm which converts nicely to 656lbs :)
  18. May 30, 2013 at 7:41 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Yep!:thumbsup:
  19. May 30, 2013 at 7:44 PM
    SoCaltaco65
    this thread is still going on? 2.5 700# spring with plate bump and winch period.
    End!
    to go down any other path with armor, plate bumper and winch is really dumb!
