Discussion in 'Street Trucks' started by 98TT2.4, Jan 25, 2021.
  1. Jan 25, 2021 at 2:34 AM
    98TT2.4
    98TT2.4 [OP] I was TUNED in Japan and now F A T here!!!
    Lazaro
    Florida
    98 Tacoma 2rz-fe 2wd extcab. SR5
    Mild lowered sport suspension, all greasable zerk points front and rear, rear 3.5" lower with 4wd springs,middle leaf pulled and 2wd overload leafs,kyb shocks, rear oem bumpstops and 4 wheel parts shackles and urethane bushings. Front lower 2" custom one off made 2" drop springs oem upper lower arms kyb shocks stock sway bar and urethane bushings, wheels18×9 square et24 Advan Racing RGD2 satin black color, Nitto 225 40 18 NT555g2 tires, ARP wheel studs front and rear, NRG real titanium wheel lugs, sport drilled and slot rotors with ceramic pads, red powdercoated oem calipers, stop tech brake lines front and rear, Motul 550 brake fluid, weight reduction all over, Stripped ext, stripped int, stripped engine bay, full carbon fiber back and black suede semi bucket seats with adjustable sliders, planted technology seat mounts, pioneer single din radio, pioneer speakers, exterior smooth radio antenna, AEM guages, 2.5l fire extinguisher with quick release bracket, blackcat custom instrument cluster guages, Nrg carbon fiber and perforated red stitch leather steering wheel, Nrg quick release for steering wheel, led interior lights,rear adjustable brake proportioning valve, 01 full cabon fiber VIS racing hood, aerocatch safety pins, window tint 35front windows 20 cab side and 15percent rear glass, single piece rear glass,led smoke red taillamps, clear red led third brake light, LCE longtube header, speed factory titanium header studs, magnaflow catalytic converter, custom stainless exhaust pipe, Borla proxs mid muffler going to rear custom notched bumper with an auxiliary vibrant real titanium 4" exit muffler, skunk2 muffler silence insert. K&N air filter, Injen air intake system, LCE throttle body spacer, egr delete, declutured engine bay, LCE fuel pressure gauge, K&N valve cover breather, LCE underdrive pulley, dual 12" electric cooling fans, Mishimoto fan controller and relay, LCE 180 degree thermostat, aftermarket black reflector headlamps with white halogen bulbs, matching corner lamps with amber led, 01 4wd fenders, 4wd modified grille, 2001 srunner front bumper, srunner front bodykit chin spoiler, clear lens amber led signal lamps, smooth tailgate handle relocation, locking gas cap, Ultra guage obd2 monitor. yellow silicone wiper blade, LCE black silicone coolant hoses, Brisk racing silver plugs, Denso ignition wires, Denso ignition coils, 7 pound lithium battery, the paint is oem original maroon color and that's why I have to paint the truck and do the bodywork. Having a nice ride takes alot of work and dedication. The only thing that's easy is to sleep and dream away.
  2. Jan 25, 2021 at 3:24 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
  3. Jan 25, 2021 at 9:12 AM
    Fredfifty
    Fredfifty Back in a Mini
    Dave
    Big Island - SF Bay Area
    99 5 Lug V6
    DJM 3/4 DJM UCA BJ FLIP CALMAX SHOCKS POLYURETHANE SWAY BAR BUSHINGS POLYURETHANE UCA BUMPSTOPS ROLLED FENDERS DJM 4 INCH ANGLED BLOCKS (STEEL) MINI C-NOTCH FROM ROHDE FABRICATIONS MJBTACO LOWPRO BUMPSTOPS CALMAX SHOCKS ROLLED FENDERS
    hit the pick n pull and grab you a fender before doing anything else to your whip
