70MPH downhill in neutral truck rapidly slows down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mexanese.502, Dec 9, 2017.
  1. Dec 9, 2017 at 7:44 AM
    mexanese.502
    mexanese.502 [OP] Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    First time doing this in this truck for troubleshooting. Did it in the old Nissan just to test the drag.
    Brie and shakerhood like this.
  2. Dec 9, 2017 at 8:00 AM
    jholc21
    jholc21 Well-Known Member
    Colorado
    2017 White Tacoma TRD OR
    Bilstein 6112/5160 w/Dakars Leafs 255/80/R17 Cooper ST MAXX Skinnies 4.88 Gears TRD Pro Fog Lights Cali Raised 5D Combo Leather Seats LED Bed Lighting ARE Overland Shell
    You could raise vehicle one tire at a time and spin it. Seeif one drags more than the other? Maybe you have a sticking caliper?
    Brie likes this.
  3. Dec 9, 2017 at 8:07 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
  4. Dec 9, 2017 at 8:10 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Is there some sort of descent control nanny turned on?
    OnHartung'sRoad likes this.
  5. Dec 9, 2017 at 8:21 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    “Tacoma Coast Guard” is already taken. D13 has good people, too!
    But you may not be far off - I’m guessing here, but maybe the Hill Assist Control may have come into play and applied braking? - I tried letting my truck coast backwards a bit on a hill (while still in drive) to have another try at a boulder as I have done a lot before in my Gen 1 Taco, and only went a few feet and the HAC activated and the brakes automatically grabbed hold. I had to put it into reverse to complete the maneuver.
    Brie likes this.
  6. Dec 9, 2017 at 8:33 AM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Going to 4H then back to 2H cleared it up? Sounds like the problem is in the transfer case or the front differential. Next time it happens try a very sharp turn if you don't get hopping then the front axle is not locked so it is most likely the transfer case.
    xxTacocaTxx, Brie and OnHartung'sRoad like this.
  7. Dec 9, 2017 at 8:36 AM
    OnHartung'sRoad
    I didn’t think of that - probably the best answer as I reread OPs description now that I had my first cup of coffee and my comprehension is better. I assumed he was not engaged in 4WD.
    Time for a dealer checkup on that system, having it locked like that is going to wear things out.
  8. Dec 9, 2017 at 8:44 AM
    mexanese.502
    Kentucky
    OV Tuned
    Sorry I screwed that Quote up
  9. Dec 9, 2017 at 8:52 AM
    mexanese.502
    Kentucky
    OV Tuned
    This seems very possible and need to keep sharp eye on this
  10. Dec 9, 2017 at 10:30 AM
    tallpilot
    David
    Florida
    Just for some more discription and operation :
    The 4H light comes on when the front differential locks so that is why it is possible to have the transfer case partially engaged with no instrument panel indication.
    Brie likes this.
  11. Dec 9, 2017 at 11:25 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Hmmm .. . . Mine flashes as soon as the rotary switch is moved. It goes solid when it's fully engaged.
    G.
    xxTacocaTxx, over60 and shakerhood like this.
  12. Dec 9, 2017 at 12:19 PM
    OnHartung'sRoad
    I hope it’s not the case, but if there’s a problem with that system, maybe it only tells you it’s fully engaged or intermittently? I dunno, Maybe a good time to have a pro check it.
  13. Dec 9, 2017 at 12:19 PM
    tallpilot
    David
    Florida
    Absolutely. The flashing is caused by switch position and disagreement with the front diff fork sensor. If the switch is in 2H and the transfer case is partially engaged there will be no flashing.
  14. Dec 9, 2017 at 12:55 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Mexican overdrive :)
    I've done that also but not in my Tacoma. If the throttle is closed Tacoma shuts off fuel so it uses less than Mexican overdrive.
    Arailt, tallpilot and shakerhood like this.
  15. Dec 9, 2017 at 8:20 PM
    #35
    mexanese.502
    Kentucky
    OV Tuned
    Saltines typically have nothing to contribute
  16. Jan 7, 2018 at 2:21 PM
    #36
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner & 2016 Taco Sport
    It's wasting gas to put it in neutral when going downhill? I've always thought the opposite, which is the whole point of doing it... No?
  17. Jan 7, 2018 at 2:31 PM
    #37
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Putting a auto in neutral when coasting I've always been told is a definite no no. I believe it has something to do with transmission fluid not able to circulate through the transmission. I could be wrong though.
  18. Jan 7, 2018 at 2:38 PM
    #38
    W8N41
    W8N41 Active Member
    2017 DCLBOR QS
    Depending on how step the hill is, your idle may go up in an auto placed in numeral going downhill. To boost brake pressure if you need to stop, since it knows the engine isn't helping. I use 'knows' relatively. Old auto's don't do that.
    On the flashing 4H, I switch back and forth allot and anytime I go from 2H to 4H and back, and the transfer case it's not where I told it to be the 4H flashes.
  19. Jan 7, 2018 at 2:40 PM
    #39
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Possibly bad gas?
  20. Jan 7, 2018 at 2:42 PM
    #40
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    When in gear and going downhill, no fuel is needed to keep the engine turning with the foot off the gas. When in neutral, under the same scenario, a little bit of fuel is needed to keep the engine turning.
    Brie[QUOTED] and shakerhood like this.
