75W-85 analysis?
Discussion in 'Technical Chat' started by Michigan Curmudgeon, Sep 5, 2017.
  1. Sep 5, 2017 at 9:54 AM
    Michigan Curmudgeon
    Michigan Curmudgeon [OP] Well-Known Member
    Has anyone done analysis on Toyota's 75W-85 LT gear oil?
    I would enjoy reading the results.
    It may be on BITOG, but I can't seem to register on that site and thus cannot use the search function. A referral to the page would be appreciated.
    Please note that I'm not after suggestions to use alternative products, nor do I need to be told to not worry about it. A general discussion of gear oils is not sought.
  2. Sep 6, 2017 at 7:59 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I was at the dealer and did a financial analysis of the Toyota gear oil. There must be gold in it since they wanted $35 a quart.:)
    Lester Lugnut likes this.
  3. Sep 7, 2017 at 8:03 AM
    btanchors
    btanchors Well-Known Member
    Dennis
    Herndon, VA
    I have a UOA (NOT VOA) on the stock stuff that came in the vehicle from the factory - Would that suffice? Of course, there is no guarantee that it is the exact same TOYOTA LT 75W-85 that you get at the dealer - it could be another contractor that supplied what was used as factory fill. I do recall it testing as a 75W-85 weight, though.
  4. Sep 7, 2017 at 8:50 AM
    Michigan Curmudgeon
    Yes indeed. I would be interested in seeing how it held up.
    If you would share that info, it would be most generous of you.
