75W-85 versus 75W-90 Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wackyhacky, Dec 21, 2019.
  1. Dec 21, 2019 at 1:25 PM
    Wackyhacky
    Wackyhacky [OP] A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Does anyone know if using 90 presents any kind of issue in the front or rear diff? 75W-85 is what is specifically called out in the owners manual, but I just went to both Napa as well an Oreilly's and neither place said the have ever seen 85 before???
  2. Dec 21, 2019 at 1:27 PM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  3. Dec 21, 2019 at 1:29 PM
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Excellent. I figured as much, but figured I would pulse the crowd to be sure. Thanks!
  4. Dec 21, 2019 at 1:54 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
  5. Dec 21, 2019 at 3:02 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    I’m running 75w-140 everywhere, except the MT-that gets MT-90
  6. Dec 21, 2019 at 3:06 PM
    j_sav115
    j_sav115 Well-Known Member
    SC
    07 Silver TURD SPRT
    Getting to start all over :)
    Why 140?
  7. Dec 21, 2019 at 5:13 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Probably aftermarket gears
    j_sav115 likes this.
  8. Dec 21, 2019 at 5:52 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    I’m running the heavier weight in the t-case ‘cause ECGS recommends it. I run it in the boxes mainly because I exceed payload quite a bit hauling my camper in the bed and do some towing with that sumbitch in there as well.
  9. Dec 21, 2019 at 6:04 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    Gotcha. Makes sense
  10. Dec 21, 2019 at 6:05 PM
    j_sav115
    SC
    07 Silver TURD SPRT
    Although I've never seen ECGS suggestions for heavier weight. Re-gear?
  11. Dec 21, 2019 at 6:24 PM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Stock gears
  12. Dec 21, 2019 at 9:02 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Red Mountain likes this.
  13. Dec 22, 2019 at 4:22 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Auto store counter help have never seen 75W-85 gear oil? That's interesting. I use 75W-85 GL-5 gear oil in my differentials as specified in owners manual. Redline products is what I use (expensive). From reading TW forums majority here use 75W-90 with no issues. Your truck your call.
    https://www.redlineoil.com/75w85-gl-5-gear-oil
