75w transfer case oil vs. 75w-85
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mas Olas, Apr 8, 2022.
  1. Apr 24, 2022 at 8:17 AM
    #81
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    coffee time omg was at dirt track racing with my family watching untill 12:30 am this morning fml need to go fast now lmao
    Otterstuff likes this.
  2. Apr 24, 2022 at 8:28 AM
    #82
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I'm sure that's true, but it's just one more reason a grumpy tech could deny a warranty repair.
    Mateo74[QUOTED] likes this.
  3. Apr 24, 2022 at 8:31 AM
    #83
    shotgunbilly420
    The only reason I back amsoil is my brothers 97 Ford powestroke is over 700,000 miles using amsoil products so that's my leverage
    SpeySquatch likes this.
  4. Apr 24, 2022 at 8:34 AM
    #84
    shotgunbilly420
    Well have fun guys I'm clocking out of this thread I've spoken my share
    Speedbird likes this.
  5. Apr 24, 2022 at 9:58 AM
    #85
    SpeySquatch
    2016 TRD OR DCSB
    If you pay the $25 and subscribe as a member to Amsoil it’s a lot cheaper…like $4-$6/quart
  6. Apr 24, 2022 at 10:24 AM
    #86
    Paddyd
    Paddyd Active Member
    Pat
    2021 Tacoma, Army Green TRD Off Road
    lift
    I know there are millions of transfer cases around the world that have lasted decades with ATF in them.
  7. Apr 24, 2022 at 10:28 AM
    #87
    maver1ck
    maver1ck Active Member
    Well what I was wondering if anyone replaced those front differential 10mm hex bolts with standard bolts similar to the transfer case and rear differential so you don't have to worry about stripping out the hex hole if the key isn't completely in all the way. That was all I was getting at. Yeah I will see how much they are at the dealer when I go on Monday for my other parts.
  8. Apr 24, 2022 at 10:29 AM
    #88
    maver1ck
    Is it okay to refill front diff and transfer case with front end of truck on jack stands, or should I wait until truck frontend is back on ground and truck is level before I refill both? Its currently on jack stands on front end as I have been working on the brakes.
  9. Apr 24, 2022 at 11:11 AM
    #89
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I don’t think it’s the tech who decides warranty claims and how can someone tell the difference in oil without testing?
    geo8866 likes this.
  10. Apr 24, 2022 at 11:13 AM
    #90
    mquibble
    Michael
    2021 TacomaTRD Pro
    https://www.toyotapartsdeal.com/
  11. Apr 24, 2022 at 11:15 AM
    #91
    mquibble
    Michael
    2021 TacomaTRD Pro
    Yep. I get your point. I’m the minority who actually prefers the 10mm hex better.
  12. Apr 24, 2022 at 11:18 AM
    #92
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    Fill them with the truck level. Getting the correct amount back in there is dependent on the fluid running out of the fill hole when it’s full. If it’s not level then you will be over or under filling by some amount.
  13. Apr 24, 2022 at 11:37 AM
    #93
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Any one here try the bmw transfer fluid or its equivalent S-tec oil0005. Buddy of mine at his shop has been using it, says its fine in these tacos.
  14. Apr 24, 2022 at 1:04 PM
    #94
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    And those transfer cases were designed to use ATF as the lubricant.
    3ed gen Tacoma isn't.
  15. Apr 25, 2022 at 11:24 AM
    #95
    maver1ck
    Np.Thanks
  16. Apr 25, 2022 at 11:24 AM
    #96
    maver1ck
    Thanks for confirming.
  17. May 14, 2022 at 7:20 AM
    #97
    Mas Olas
    Mas Olas [OP] Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Been on a time out and wanted to close this thread. Rear was milky black and front was light caramel colored. Next change will be with the tcase around 90-100k.
    tonered and Wulf like this.
  18. Feb 23, 2023 at 3:48 AM
    #98
    shotgunbilly420
    Amsoil 75 90w
  19. Nov 21, 2024 at 1:21 PM
    #99
    HottNikkels
    HottNikkels Member
    I know this is an old thread, but I was doing research on if 75w oil was really needed for the transfer case so I called my local Toyota dealer. I live in Winnipeg, Canada and the dealer here said they do not even have the 75W ever in stock, he did a search for me and informed me there isn't even any available in any Toyota dealership in Canada! He told me they use 75w-85 or 75w-90 in all of their transfer cases. This is in line with what another member said on this thread as well. Judging by this I would say it's probably fine to use 75w-85/90 in the transfer case.
    RotorRPM likes this.
