76,000 mile oil change.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Saguarobandit, Apr 23, 2020.
  1. Apr 23, 2020 at 10:04 PM
    Saguarobandit
    Saguarobandit [OP] Well-Known Member
    2017 Tacoma 4X4, on the seventh oil change at 76,000 miles.
    Front and rear diff lube done at 67,240
    Spark plugs done at 62,300
    Front brake pads replaced
    Transmission fluid exchange at approximately 55,000.
    Three sets of tires.
    Countless amount of engine air filters
    Wipers blades
    Front Bilstein shocks and rear Tuff country shocks done (front left axle seal and bearing done with Bilstein shock lift).
    No issues to report with this truck.
    https://www.youtube.com/watch?v=U_TWfoJn-F0&feature=share
  2. Apr 24, 2020 at 5:34 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Three sets of tires sounds excessive in just 76,000 miles.
    BalutTaco, IEsurfer, Skydvrr and 6 others like this.
  3. Apr 24, 2020 at 6:37 AM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    i was on my third set when i sold it at 87K miles.....I dont think the tires that come from the dealer are the same tire you buy off the rack from a tire store. Its almost like they make that quality of tire specifically for car manufactures to last 30k miles regardless of what that wear rating says.
    Thats a badass rig OP! How much weight is the trailer when your horses are loaded?
    specter208 and SandyTaco4x4 like this.
  4. Apr 24, 2020 at 6:41 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Given the thread title ,I'd have expected a truck that had it's first oil change in 76,000 miles. Not a random oil change report.
  5. Apr 24, 2020 at 6:44 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    same here
    w.adventures and Malvolio like this.
  6. Apr 24, 2020 at 12:09 PM
    Saguarobandit
    Two horses, 2 mountain bikes, kayaks and all other hiking food and gear.
    2016Tacoman and Malvolio like this.
  7. Apr 24, 2020 at 12:15 PM
    Saguarobandit
    I'm on the third set. OEM Goodyears wore out quick. Second set were BFG K02. Currently on BFG KO2 again.
    mullett757 likes this.
  8. Apr 24, 2020 at 12:21 PM
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Nice! I'm at 70k on the odometer and roughly 75k calculated for tire size with a very similar list of maintenance (a couple more diff fluid and tcase fluid changes in there because of I abuse the truck). If it makes you feel better I am at the end of life for tire set #4 (sold the second set to upsize and third set was used). I've been doing oil changes every 8k on the odometer which ends up at 9,120 actual miles.
    Saguarobandit[OP] likes this.
  9. Apr 24, 2020 at 12:22 PM
    Saguarobandit
    Check out the OEM plugs I changed. I did them I bit early but glad I did because the gap was off. I replaced them with Toyota OEM.
    splitbolt, Bleep100 and DAS Taco like this.
  10. Apr 24, 2020 at 12:31 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Agreed. I wonder if he post on the Whirlpool refrigerator forum when he replaces his water filter?
    cosmicfires and w.adventures like this.
  11. Apr 24, 2020 at 12:51 PM
    Saguarobandit
    I used to post on Stangnet when I had my 1990 Mustang LX. I was part of IMBOC when I had my 2008 Bullitt Mustang.
    I was a Mustang guy for over twenty years. I bought my first used Mustang in the Army back in 1996. Sold my last Mustang this year and now just posting here on Tacoma forum.
    Front sight, Skydvrr and Harperspop like this.
  12. Apr 24, 2020 at 1:10 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Such a hater.
    ShttrMech11A799 and SandyTaco4x4 like this.
  13. Apr 24, 2020 at 1:15 PM
    Kevin Jones
    Kevin
    Va
    Burning nice and clean.
  14. Apr 24, 2020 at 1:29 PM
    reloader403
    Acworth, GA
    speaking of plugs, my passenger side most forward plug was finger tight in that cylinder for the 58k miles it was installed.....truck never showed any issue. Tough freakin truck.
  15. Apr 24, 2020 at 1:31 PM
    reloader403
    Acworth, GA
    Man that is a load!
  16. Apr 24, 2020 at 1:45 PM
    Saguarobandit
    Yeah, Total weight with truck. We gassed up and drove right on the scale. We were going to Big Bear. The horses weight about 1000 lbs each.
  17. Apr 24, 2020 at 1:52 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Welcome to TW, please ignore the dipwads. There is an ignore button.
    Plug doesn't look bad at all.
    Bleep100 likes this.
  18. Apr 24, 2020 at 1:55 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Funny you mention that. Some of the plugs would end up finger tight on my tundra even after torqued to spec. Suspect some minor detonation was occurring.
    On another note be sure to coat the plug treads with a very thin coat of never-seize before installing.
  19. Apr 24, 2020 at 1:59 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Did you put your truck drive axle + trailer axle on the same pad? How do you know what the trailer weight is?
  20. Apr 24, 2020 at 2:03 PM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    The plugs, are they Denso iridium?, thanks
