77000 Miles and Just Oil Changes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Binny, Dec 24, 2009.
  1. Dec 24, 2009 at 1:53 PM
    Binny
    Binny [OP] Member
    I have a 2005 Toyota tacom trd Sport Sr5.. The only thing I have done to it was change the oil and brakes... I mean really thats it... I want to treat her right for Christmas.. What maitnence should I do.. I do not have the book or I would not ask.. I heard some people warn me about the timing belt and others say do the tune up at 75 some say 100... Any advice...
  2. Dec 24, 2009 at 1:55 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Definitely want to take a look at the belts and pulleys. I replaced all of mine at 50,000.
  3. Dec 24, 2009 at 1:57 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    air filter, oil change, grease driveshaft and transfer case, spark plugs, change out differential oil, tire rotation, check brakes.
  4. Dec 24, 2009 at 2:03 PM
    Binny
    Binny [OP] Member
    The drive shaft and transfer case is something I could do by myself or I have to bring it in...
  5. Dec 24, 2009 at 2:03 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
  6. Dec 24, 2009 at 2:21 PM
    Binny
    Binny [OP] Member
    How much did it cost you to do all of your belts and pulleys....
  7. Dec 24, 2009 at 5:10 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    I think like $250 for parts, my dad and I installed everything ourselves then had a local shop look at everything to make sure we did everything right. :p
    (We did...:p)
  8. Dec 24, 2009 at 9:39 PM
    sierra141
    sierra141 Well-Known Member
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    You have a timing chain no maintance required not a timing belt
  9. Dec 25, 2009 at 9:50 AM
    Binny
    Binny [OP] Member
    Im clueless..... Thats what happens when u have a truck that nothing ever goes wrong on....LOL.... So I have a chain... Do they ever go... Or do they need to be replaced at a certain amout of miles like the belt.???
  10. Dec 25, 2009 at 9:57 AM
    sierra141
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    No they are good for lifetime Ive had 80's Toyota trucks with timing chains never had to replace one. One of those trucks had 290,000 miles when i sold it still original timing chain. I still see the truck around town runing like a champ just remember to change your oil regularly don't neglet your truck
  11. Dec 25, 2009 at 10:20 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Timing chains are very durable, but sometimes their tension actuators get a little loose after many miles.
    If I were you, I'd be more concerned with your spark plugs, fluids, and greasing. Look in your owners manual at the 30,000mi/60,000mi service interval and make sure all that is taken care of.
    Might not be a bad idea to flush/replace the engine coolant as well at that mileage, and if its an Auto-Trans, have the trans fluid changed.
  12. Dec 25, 2009 at 11:21 AM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    I'd say look over the maintainance manual. Spark plugs, engine a/f, in cabin a/f, oil, oil filter and lube the driveline components are all that is required at 30K unless you towed 15K or more miles of the first 30K miles. A lot of people say change rear diffy fluid, transfer case, etc... but it's not required according to the manual for most drivers.
    I haven't checked the manual for anything past 30K but would only recommend following the manual. No need to spend money on something Toyota doesn't recommend.
    I've followed this philosophy on the wife's Sequoia. It has 132,000 original miles and is still going strong. Original diffy, tranny, engine, and everything else.
  13. Dec 25, 2009 at 4:05 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    I disagree. I have had 2 4runners (84 and 85) and an 81 celica all needed timing chains ( all at around 300,000 miles). My one 4runners chain got so lose it ate a hole in the water pump housing.
    Personally I prefer a belt and would rather pay $200 every 60,000 miles to have it replaced and know that it has been done.
    Just my opinion though as all my cars have had high miles
    Shawn
  14. Dec 25, 2009 at 4:29 PM
    jandrews
    300,000 generally speaking is considered beyond the expected life of the motor...hence why most companies say they are good for the life of the motor (most car companies put that around 250k miles tops). Toyota and Honda however...well, that's an easy number to blow away.
    Your point about the loose chain is what I was getting at earlier...checking the chain tension every 30,000 miles or so and adjusting as necessary is a good idea.
