7mpg?!
Discussion in 'Towing' started by kalaniwavo, Dec 31, 2011.
  1. Dec 31, 2011 at 6:13 PM
    kalaniwavo
    kalaniwavo [OP] Member
    Nick
    NORCAL
    11Tacoma
    camper shell
    Just took our travel trailer on its maiden voyage and was blown away at how horrible the mileage was. I expected bad, maybe somewhere between 9 to 11 but I got 7mpg?!
    I'm towing with a 2011 Taco DC LB 4x4 with a Leer camper shell. Our travel trailer is 19ft and 4500lbs loaded. Trip was on flat ground, no wind and stayed around 60 and never went above 65. Aired all the tires up to 37psi before we left and stayed in 4rth gear (automatic)
    I read alot of posts on here before we bought our trailer and it seemed, even the guys that were towing 24ft++ trailers, were getting somewhere above 9mpg. Am I missing something? Was planning on towing the truck up the Sierras and doing some camping in the mountains at Tahoe this year but I'm having second thoughts now.
    What do you guys think!?
  2. Dec 31, 2011 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Tow in 5th, unless the tranny trys to hunt.
  3. Dec 31, 2011 at 6:14 PM
    kalaniwavo
    Nick
    NORCAL
    11Tacoma
    camper shell
    Happy New Year by the way!!!
  4. Dec 31, 2011 at 6:19 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Heaviest trim level truck. Camper shell. 4500lb trailer. Highway speeds one ratio down from top gear.
    Where's the surprise?
  5. Dec 31, 2011 at 6:25 PM
    kalaniwavo
    Nick
    NORCAL
    11Tacoma
    camper shell
    Just because I don't think I've ever heard anyone admit to actually getting 7mpg. I have freinds with full size trucks and Class A gasoine RV's that get better gas mileage. I figured at worst I would be getting the same mpg as them, but not any worse
  6. Dec 31, 2011 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I'd bet you would have been closer to 10 if you were in 5th.
  7. Dec 31, 2011 at 6:27 PM
    jandrews
    Agree with this.
  8. Dec 31, 2011 at 6:33 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Does the TC lock in 4th ?
  9. Dec 31, 2011 at 6:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  10. Dec 31, 2011 at 6:39 PM
    OZ-T
    Peter North
    British Columbia
    So just D and 4th , no ?
  11. Dec 31, 2011 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I know it locks in both 4th and 5th, but I was reading in Popular Mechanics, and they statted that it can also achieve "partial lock" in 3rd. Most TC's lock either On or Off, where as the one on the Tacoma can have varying degrees of lock.....However, aside from that article, I havent found anything else to back that up. Everytime I have the opertunity to test this in my truck, I forget.
  12. Dec 31, 2011 at 6:46 PM
    OZ-T
    Peter North
    British Columbia
    Thanks 16
  13. Dec 31, 2011 at 6:47 PM
    jandrews
    First I was like :confused:
    But then I was like :cookiemonster:
  14. Dec 31, 2011 at 6:54 PM
    chugchug
    chugchug Well-Known Member
    Will
    Frederick MD
    2012 Toyota Tundra
    Dont feel bad I had an 2005 v6 dbl cab 4x4 short bed and was pulling my hybrid camper witch loaded 5900lbs. Dont get me wrong the fricken truck pulled and on flat ground and you didnt even know it was there accept in mpg. But it didnt like hills tho. So went and bought it,s bigger brother 2012 tundra dblcab 4x4.
  15. Dec 31, 2011 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :homer:
  16. Dec 31, 2011 at 7:54 PM
    kalaniwavo
    Nick
    NORCAL
    11Tacoma
    camper shell
    so you guys think it would be ok towing in D as long as its the tranny isn't hunting? I know everyone has their own opinions but I thought the general consensus was never tow in D. I'll have to do some experimenting...
    About how much do shells weigh anyway? We got the shell to camp in the back but have a newborn now (reason we upgraded to trailer) so no need for it anymore. Might help the mpg a little (realistically maybe 1/8mpg) =)
    Thanks for the responses! I'll keep tweaking and see what I come up with. There is def a learning curve with rv's and went pretty well for our first weekend until we packed up camp drove off and 20miles down the road I remembered I left my full cup of coffee in the microwave! made a mess but was good for a good laugh!
  17. Dec 31, 2011 at 7:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not towing in Over Drive or the 5th gear in our Tacoma, is a thing started back in the 70's, as the OD gears were a very weak planetary gear set. Now, there is no issue towing in "D", and letting the tranny do its thing.
  18. Dec 31, 2011 at 8:01 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Im not really even sure when i "need" to use overdrive, or when it would be useful, the tranny downshifts whenever it needs to
  19. Dec 31, 2011 at 8:02 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    If you do come up & want to hit a trail with some fellow TWers give us some advance notice and we can probably set up a run. http://www.tacomaworld.com/forum/south-west/167767-reno-sparks-trail-run.html
  20. Dec 31, 2011 at 8:12 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    I have to agree with this ^^
