7P Recovery Ring
Discussion in 'Recovery' started by BlindingWhiteTac., May 30, 2018.
  1. Nov 6, 2019 at 9:02 AM
    #101
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Fair point; however by "tension" I mean extreme tension, where you're doing something like placing the weight of the vehicle you're winching out against it.
    A good knot will only reduce the safe working strength of a rope by 50%; poor knots, as much as 90%, depending on the material. A proper splice can reduce the strength by as little as 10-15%.
  2. Nov 6, 2019 at 9:10 AM
    #102
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Figure 8 and Bowline are about 75%-80% of the line strength. There are other knots that are stronger (approaching 90%) but they aren’t as easy to untie.
  3. Nov 6, 2019 at 2:42 PM
    #103
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Cant wait to see how over-priced that will be :D
  4. Nov 6, 2019 at 2:53 PM
    #104
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    MSRP is $110.
    Gunshot-6A likes this.
  5. Nov 6, 2019 at 4:34 PM
    #105
    SR-71A
    Zack
    Southern Maine
    Wow :rolleyes:
  6. Nov 13, 2019 at 4:14 PM
    #106
    cwadej
    cwadej Ballerina Award winner
    Right Here
    2011 Access Cab 4x4
    I wonder how one of these would perform on a steel shackle instead of the soft one.
  7. Nov 13, 2019 at 4:25 PM
    #107
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The steel would start to chew up/gouge the aluminum almost immediately. It'll "work" but would definitely shorten the ring's life span.
  8. Nov 26, 2019 at 6:15 AM
    #108
    MartinDWhite
    MartinDWhite Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    I made a few of these, hit me up if you want one for $50 each plus $10 shipping per order.
  9. Nov 26, 2019 at 6:17 AM
    #109
    MartinDWhite
    Martin
    Greenville, SC
    I think it would also start to unscrew the pin if the pin was the rotation point, I don't think the non-pin side could be put in the hole. Either way, it's not how they were meant to be used.
  10. Nov 26, 2019 at 7:12 AM
    #110
    SR-71A
    Zack
    Southern Maine
    Been busy huh? Those look good. Any other colors?
  11. Nov 26, 2019 at 7:26 AM
    #111
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    What size are those? If it was covered before, I missed it.
  12. Nov 26, 2019 at 7:46 AM
    #112
    MartinDWhite
    Martin
    Greenville, SC
    4.75" outer diameter.
    First run in blue only. Is there a color you would prefer over blue?
    Bastek[QUOTED] likes this.
  13. Nov 26, 2019 at 8:32 AM
    #113
    SR-71A
    Zack
    Southern Maine
    Red might be nice. I already have one of your original bare Al ones (still haven't even used it yet..)
  14. Nov 26, 2019 at 8:51 AM
    #114
    MartinDWhite
    Martin
    Greenville, SC
    I didn't go red from the local anodizer because it is more of a maroon, and it has a tank change fee because it is so rarely run.
    They offer Green, Blue, and Black standard. Orange and yellow are also available for a tank change fee.
    I have used mine several times, which is one of the original bare aluminum ones. I just added a blue one to the recovery kit from this batch.
  15. Dec 4, 2019 at 8:45 PM
    #115
    cwadej
    Right Here
    2011 Access Cab 4x4
    assuming i use it to come back to the truck, not just change direction to a solid anchor, do these rings turn as the winch line passes over it, or does it stay stationary?
  16. Dec 4, 2019 at 9:01 PM
    #116
    GHOST SHIP
    GHOST
    It rotates slightly but the synthetic line can also slide over the ring without harming it or burning the line due to the slow speeds when winching under load.
    madcratebuilder likes this.
  17. Dec 5, 2019 at 3:27 AM
    #117
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Ring spins while winch line passes over it.
    You can kinda see it here
    https://youtu.be/2KwLQ59UuhY
    chrslefty likes this.
  18. Dec 5, 2019 at 8:49 AM
    #118
    cwadej
    Right Here
    2011 Access Cab 4x4
    great video find, thanks for that.
  19. Dec 5, 2019 at 8:51 AM
    #119
    lojack
    lojack Well-Known Member
    Ahren
    South Shore, Wi
    19 DCSB OR CB
    That's cool and all, but I would NEVER step over a winch line under load.
    MartinDWhite likes this.
  20. Dec 5, 2019 at 10:38 AM
    #120
    cwadej
    Right Here
    2011 Access Cab 4x4
    Nor would I. That wasn't under a load. Literally less tension per line than if you were pulling it by hand with a single line.
    SR-71A, MartinDWhite and DarkMark340 like this.
