7th Injector
Discussion in '1st Gen. Tacomas (1995-2004)' started by closha63, Nov 28, 2008.
  1. Nov 28, 2008 at 9:19 PM
    closha63
    closha63 [OP] QuickShift
    York Springs, PA
    04 SR5 TRD
    3'' Though Country Suspension lift, Grey Wire Mod, Cold Air Intake, Tundra TRD Exhaust Tail pipe ( all custom pipe) Sounds real mean!! Huculiner bed protectant, Rear diff. Breather Mod.
    Well i was wondering if any has done a 7th injector install without a supercharger. Is there a way to hook this up?
  2. Nov 28, 2008 at 9:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If your thinking for a turbo aplication, shouldnt be too hard. you'll have to mount the injector in the intake track, before the manafold. May take some custom work, other than that, it should be an easy hook up.
  3. Nov 29, 2008 at 8:18 PM
    closha63
    York Springs, PA
    04 SR5 TRD
    Well the thing is that i was just thinking about doing the 7th injector install no forced induction at all. Wondering if it is worth it????
  4. Nov 29, 2008 at 8:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You would run WAY to rich. The injectors under WOT are only running around 80 to 90% max flow as it is. SO, If you ran the 7th injector on a NA engine, you would make LESS power. :)
