7TH INJECTORS??
Discussion in '1st Gen. Tacomas (1995-2004)' started by jacob.johns.jj, May 3, 2013.
  1. May 3, 2013 at 3:40 PM
    jacob.johns.jj
    jacob.johns.jj [OP] Member
    jacob
    Georgia
    tacoma 4x4 SR5
    3 inch susp. with 33x12.50 toyo MTs with 18inch XDs. K&N cold air intake
    can i put the 305 injectors that are in the supercharged 3.4L in my 3.4L engine without a supercharger and will it make a difference in power?
  2. May 3, 2013 at 3:41 PM
    jacob.johns.jj
    jacob
    Georgia
    tacoma 4x4 SR5
  3. May 3, 2013 at 6:58 PM
    BamaToy1997
    Bill
    Navarre, FL
    There will not really be any noticeable gain in performance if you do not have the supercharger to add the air needed to go with the additional fuel. You most likely will end up setting a rich code.
  4. May 3, 2013 at 8:40 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    As said..no difference will be made. The ECU won't sense any more Air so it won't add any more Fuel.
    Motors are big fancy air pumps. You need more air to add more fuel which equals more power.
    realistically, nothing will happen. You just won't be utilize the flow that those injectors can do.
  5. May 6, 2013 at 12:54 PM
    jacob.johns.jj
    jacob
    Georgia
    tacoma 4x4 SR5
    thank you all very much!!!! so if i have a cold air intake and a throttle body spacer still no good???
  6. May 6, 2013 at 1:09 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
    Still not enough air being fed to notice any bit of difference.
  7. May 6, 2013 at 1:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    TB spacer does nothing to our trucks.
    Stock intake is already a CAI
    so..no.
