7way to a 4 way female adapter
Discussion in 'Towing' started by Vanellies, Mar 18, 2011.
  1. Mar 18, 2011 at 5:29 AM
    Vanellies
    Vanellies [OP] New Member
    03 SR5 TRD 4 door double Cab
    Hello,
    I just picked up a 7 to 4 way adapter. I have a question about the blue and yellow and white wires. I'm pretty sure that you hook the blue wires up to your back up lights. I think white is the ground, but where does the yellow wire go? Also how do I gain access to the blue backup lights so I can splice them all together?
    I have a 2003 double cab TRD Tacoma
    Thanks
    Van
  2. Mar 18, 2011 at 5:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Pics would help. Did the wiring harness come with any sort of wiring diagram? If I'm reading your post correctly, you're trying to wire up a 4-pin trailer wiring harness?? In which case, you do not tap into your back-up lights. The 4 wires would connect to the brake/running lights, one for each turn signal and one is a ground.
  3. Mar 18, 2011 at 6:03 AM
    Vanellies
    I already have a 4 way flat I'm trying to install a 7-way round, because my trailer has breaks on it.
    Here is the part I have purchased. http://reese.cequent-cpi.com/product/detail.asp?ID=85342
    I was just wondering how I would gain access to the wires, so I could splice the yellow to the reverse lights and also hook up the blue and black wires.
    Thanks
    Van
  4. Mar 18, 2011 at 6:04 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Are you talking about this?
  5. Mar 18, 2011 at 6:07 AM
    Vanellies
    Yes that is it.
  6. Mar 18, 2011 at 6:20 AM
    Pugga
    Massachusetts
    Sorry about that... scratch my last post, I misunderstood what you were asking about.
  7. Mar 18, 2011 at 6:49 AM
    Bama_TACO
    Winfield, AL
