8” IFS Clamshell w/FRS Torsen
Discussion in 'Technical Chat' started by bwawuz02, Jul 29, 2018.
  1. Dec 29, 2018 at 3:14 PM
    #181
    bwawuz02
    bwawuz02 [OP] Well-Known Member
    I have not looked at the 16+ differential, but I’m about to do my first oil change since getting the mechanics of the AWD working (5k miles) and it seems to be settling in nicely. I love the truck this way, especially in PNW weather. I don’t plan on going over 32” tires so the 3.91 was plenty gear for me and readily available.
    BassAckwards likes this.
  2. Dec 29, 2018 at 6:10 PM
    #182
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    https://www.yukongear.com/diffdetails.aspx?DiffID=255&PartsLink=PartCats.aspx?SearchMode=Make&MakeID=12&MakeName=Toyota&ModelID=404&ModelName=Tacoma&Side=Front&DriveType=4WD&DiffID=255&DiffName=Toyota+8%22+IFS+Clamshell+Front+SD20B
    I would call it a maybe. Accordingly to the Diff Wizard of Yukon Gear, They specify the 8in Clamshell between 2005-17... knowing the 3rd gen starts in '16, it may be the exact same housing. Note that this does not consider the brackets to attach the diff to the frame. We would need someone to be a guinea pig and check fitment.
    I think you have made a great choice on gears. I am personally running 32" in the winter and 33" in the summer on 4.30 gears with the automatic transmission. Is yours a MT?
    bobsuruncle[QUOTED] likes this.
  3. Dec 29, 2018 at 6:55 PM
    #183
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    What was your experience like switching from presumably 3.91 to 4.30? Who did the work for you on swapping the gears?
    I'm running sliders, skids, and a canopy with gear year round on my DCLB,and am finding myself switching down gears often as the truck feels a bit sluggish. I'm running 32" winters as well, and looking at running 33" this summer potentially.
    bobsuruncle likes this.
  4. Dec 29, 2018 at 7:27 PM
    #184
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    How's that working for you? I'm wanting to run 4.30's and daily driver on 33's and 35's on occasion for trail runs etc... Trying to grab a elocker 4.30 from a 3rd gen t4r and I may be the guinea pig that trys to swap a 16+ clamshell with 4.30 into the front of my truck.
  5. Jan 4, 2019 at 8:17 AM
    #185
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Late to the game, but bravo Sir!
  6. Jan 5, 2019 at 9:21 AM
    #186
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Same here. I'd love awd and 4:30's. Might actually have traction then.
  7. Jan 6, 2019 at 8:27 AM
    #187
    bwawuz02
    Truck just got it’s first test in actual low traction conditions, snow/ice in BC. With just the front and rear torsen diffs and the shittier than stock tires that came on it, she’s getting around just fine. I can’t wait to get decent tires and brakes that work, lol.
  8. Jan 6, 2019 at 2:20 PM
    #188
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Welcome to BC. Enjoy the mild weather.
    bwawuz02[QUOTED][OP] likes this.
  9. Jan 6, 2019 at 11:13 PM
    #189
    bwawuz02
    Nope, mine is automatic. Once the drivetrain and brakes are sorted I will eventually supercharge it. Would be really cool if @Gadget@URD got a Whipple kit together for us in the next yearish ;)
    Lord Helmet and BassAckwards like this.
  10. Jan 14, 2019 at 11:45 AM
    #190
    2BeersPlease
    2BeersPlease Well-Known Member
    Stumbled across this thread searching for info on using torsen units in 3rd gen (2016) front diffs. This is very interesting.
    Would it be unsafe to assume that if the OEM FRS unit works, then equivalent aftermarket LSDs would as well?
    EubeenHadd likes this.
  11. Jan 16, 2019 at 4:00 PM
    #191
    bwawuz02
    It's usually unsafe to make assumptions. Based on known bearing sizes for multiple diffs/housings across Toyota/Lexus products is how I came to at least an informed wager that the FRS unit would work. From talking to @ZUK, it seems that some aftermarket units that might fit have known issues with oiling/inner-radius/circlip where the front CV shafts are inserted. With the FRS unit my front CV shafts popped right in with a little tap (imagine holding the CV shaft in place with one hand and trying to get a decent swing in a narrow space with the other) and I've had zero issues in 6k miles.
    My recommendation, if you just want to be rid of the front end vibes for good and have a tame steering wheel (in AWD like my truck), would be to swap in a 4-pinion carrier. The needle bearing vibe isn't from the needle bearing, it's from the inner casting of the 2-pinion carrier (in video at 0:57):
    The 4-pinion carriers should fit similarly, but are machined to exact tolerances and should eliminate vibes for good. As an example, the Lexus trucks come with a 4-pinion machined front diff (in what is basically an inverted FRS housing).
  12. Jan 18, 2019 at 9:27 AM
    #192
    Barnburner
    Barnburner Well-Known Member
    2015 Tacoma SR
    I don't think I saw this in the thread yet - is it possible the FRS unit fits the stock taco front diff if I wanted to keep the ADD system? (with the intention of locking a 4runner/FJC transfer case to keep the potential use of 2wd)
  13. Jan 18, 2019 at 9:34 AM
    #193
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Should, yes. There is no difference in the taco vs fj tube.
  14. Jan 18, 2019 at 11:46 AM
    #194
    Barnburner
    2015 Tacoma SR
    Thanks! I definitely have the wheels turning...
    Forgive me if this is a stupid question - what keeps the FRS diff from working in the rear too?
  15. Jan 18, 2019 at 1:08 PM
    #195
    bwawuz02
    I think it would also fit the rear if you’re looking for something cheaper than a TrueTrac, you can usually find whole FRS rears on eBay for $4-500ish. Lexus IS300 uses the exact same unit, but will be luxury taxed.
  16. Jan 18, 2019 at 2:06 PM
    #196
    Barnburner
    2015 Tacoma SR
    Thanks. That might be the way I end up going. Makes matching the ratios that much easier.
  17. Jan 27, 2019 at 5:55 PM
    #197
    bwawuz02
  18. Jan 28, 2019 at 4:53 AM
    #198
    YamaDirtrider
    Josh
    Elizabeth CO
    Think the info your looking for is in here.
    And yes, I have the 4runner tcase which gives me RWD, AWD, and 4WD electronically shifted it was the v6 models. The v8’s were full time awd, 4wd
  19. Jan 30, 2019 at 5:39 PM
    #199
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    Just happened across this baller thread! Kudos bwawuz!
    Once upon a time, years ago... I asked about putting Eaton Truetracs front and rear in my '04 DC TRD OR. The e-locker snobs about laughed me off the forum. My idea then was Truetracs front & rear, with the stock Taco transfer case... with an eye towards someday putting the same transfer case that came in my wife's '08 T4R Sport (V6 Auto).
    Please forgive the late, and n(.)(.)bish questions... but...
    Why go with the FRS unit(s) in the front? Why not put a Truetrac in the front diff and call it good? Or is this where a 2-pinion / needle bearing something-or-other (sorry, I'm not going to be as mechanically up to speed as most all of you) causes undue vibration in the front end, so you went with a different front diff to avoid a vibration issue?
    With my idea, I was going to find a 1st gen Taco Pre-runner or 2WD axle off CL or Ebay or just the interwebs, and simply swap out my whole rear axle. What am I missing with the rear axle?
    Thanks for keeping a running score as you project has progressed. :cheers:
  20. Jan 30, 2019 at 5:42 PM
    #200
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    The FRS unit that he installed is an Eaton Truetrac. There is no Eaton Truetrac listed for the Tacoma front diff.
