8” IFS Clamshell w/FRS Torsen
Discussion in 'Technical Chat' started by bwawuz02, Jul 29, 2018.
  1. Jan 30, 2019 at 6:13 PM
    #201
    2BeersPlease
    2BeersPlease Well-Known Member
    I asked @ZUK about that back in September. He said, "... the driver side stub shaft does not stay fully seated and leaks gear oil out." .
    ECGS now offers a TrueTrac for 7.5 clamshell.
  2. Jan 30, 2019 at 8:18 PM
    #202
    steve2267
    steve2267 Small Mammal Fire Support Team
    Colorado
    04 Double Cab Tacoma 3.4L 4WD/TRD
    bwawuz02, have you had a chance to get loose in some snow / slush / icy conditions? How has she behaved? Have you had any issues on really slick stuff where all four wheels lost traction (i.e. spun) and the vehicle started sliding left?
  3. Jan 30, 2019 at 10:40 PM
    #203
    bwawuz02
    bwawuz02 [OP] Well-Known Member
    I drove through some pretty deep slush in BC last month with zero issues, but was all at slow speeds @ Whistler. Tires on my truck are junk from the previous owner, too. I really didn't try to get loose in it though, and I grew up in snow so I'm sure I naturally adjusted to the conditions. No sliding at any point, and I don't have A-TRAC/VSC installed, yet.
    Torspd, 05Taco4x4 and VE7OSR like this.
  4. Feb 11, 2019 at 1:23 PM
    #204
    darcycook
    darcycook Well-Known Member
    2005 4x4 Toyota Tacoma
    So is the 2005 Tacoma is a 7.5 clamshell. i have always wanted a true track installed ,but Eaton never come threw i have a ARB like it but would like True Track better
  5. Feb 11, 2019 at 2:11 PM
    #205
    2BeersPlease
    I think the 2nd gens are 8".
    05Taco4x4 likes this.
  6. Feb 11, 2019 at 2:13 PM
    #206
    elclem21
    elclem21 Quebeker
    Clément
    Alberta, Canada
    2009 Tacoma TRD DCLB
    OME 885x front, TC UCAs, OME Dakars rear, 4.30 gears, Eaton Detroit Truetrac (rear diff), HomerTaco Raptor Style satoshi grill
    1st Gen Tacoma (1995-2004 and maybe very early 2005) is a 7.5in Clamshell
    2nd Gen Tacoma (2005-2015) is a 8in Clamshell
    Ensure to identify your generation correctly and it will dictate what's under it.
    tinker_troy and 05Taco4x4 like this.
  7. Mar 9, 2019 at 1:42 PM
    #207
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Is it possible to run the FJ AWD tcase with a taco front diff & cvs? Or do you have to swap all that out? The goal here being to convert my truck to AWD
    I am going to run the ADD delete with the awd fj diff tube. Just curious what the easiest way to convert it to AWD would be?
    tinker_troy likes this.
  8. Mar 9, 2019 at 2:50 PM
    #208
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Assuming that the input shaft of the FJ AWD tcase mates to the Tacoma 6-speed, you should just need the AWD FJ diff tube like you mentioned. The front diffs are the same for the Taco and FJ.
    BassAckwards[QUOTED] likes this.
  9. Mar 9, 2019 at 5:55 PM
    #209
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    For your prerunner all yo need to do is swap in a 4th gen 4runner tcase and tranny. It will give you rwd, awd, 4x4, and 4low
  10. Mar 9, 2019 at 6:04 PM
    #210
    BassAckwards
    Is it any different if converting a 4wd to AWD? and is that case you're talking about out of the limited w/ the v8 and AWD?
  11. Mar 9, 2019 at 6:23 PM
    #211
    YamaDirtrider
    Josh
    Elizabeth CO
    Yes, the taco tcase has a single shift motor. The t4r case has 2 shift motors, as well as, more limit switches. The tcase wound need to be out of the v6 model. The v8 tcase is full time awd/4x4.
    The v6 tcase is the multi select aka 2wd/awd/4x4.
    The v6 tcase will mate to your current tranny
  12. Apr 26, 2019 at 9:29 AM
    #212
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Great thread.
    I do apologize in advance for not doing my own research before asking the below question, but then again why re-research the wheel when others have already done it.
    I have a line on a low-mileage FRS differential. I am re-gearing (already have Detroit TrueTrac in the rear) and for $450, it would be great to throw the FR-S one in at the same time.
    The FJC carrier compared to the FRS diff at the beginning appears very compatible with minimal modification. Is the FJC carrier and differential case exactly the same as a base model SR-5 open diff?
    BassAckwards likes this.
  13. Jul 10, 2019 at 5:49 PM
    #213
    BassAckwards
    We meet again.. im sorry man, i thought i remembered asking this and talking to you about this once before but couldnt find it.. well here it is lol
    Would going this route require wiring of sorts? Seems like that woild have to happen to get the t4r case to work properly. I am also trying to avoid as much wiring as possible with this swap.
    Best case scenario would be to bolt it in, have manual shift locking center diff and full time awd like with the fj with the 40/60 power split while unlocked
  14. Jul 10, 2019 at 6:38 PM
    #214
    YamaDirtrider
    Josh
    Elizabeth CO
    Yea it’s gonna take a fair bit of wiring. You’ll have to wire the 4wd switch and locker switch. As well as the harness from the ecu to the tcase.
    Also if you haven’t thought of it you’ll need to modify the tranny crossmember. The tranny mount is different size between the 2wd and 4wd
    If ya don’t wanna have yours cut up, I’ve got my old one for sale.
  15. Jul 10, 2019 at 6:46 PM
    #215
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Bump to this question
  16. Jul 10, 2019 at 6:52 PM
    #216
    Clayfri77
    Clayfri77 Well-Known Member
    05 Tacoma TRD-Off Road
    The 2005 Taco is 7.5 clamshell not an 8 dont be fooled
  17. Jul 10, 2019 at 9:43 PM
    #217
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    o_O
    You're 100% sure on that? So can that means I can take a 86-2004 front diff and put it into a 2005, 2nd gen tacoma? But only the 2005? Would this also not work with a 2003 t4r?
    I'm pretty sure you're wrong, but I've also been wrong before.
    Athlaos likes this.
  18. Jul 10, 2019 at 9:58 PM
    #218
    Athlaos
    Leigh
    Edmonton
    I ended up buying the FR-S diff... reading a bit more it looks like drilling out the ring bolt holes and mild clearancing of the housing is all it takes.
    Does anyone know what size I need to drill the holes out to?
  19. Jul 10, 2019 at 10:09 PM
    #219
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Just read the thread . It’s all explained on the first several pages
  20. Jul 11, 2019 at 1:51 PM
    #220
    Clayfri77
    As long as the gearing is correct and the mounting points are the same yes. I would consult some specs to make sure the spline count on your pinion and the 05 clam shell pinion are correct as well. If not you will have to purchase a new yoke to fit the 05 pinion spline count. I own a 05 so yeah I am very sure.
