8” IFS Clamshell w/FRS Torsen
Discussion in 'Technical Chat' started by bwawuz02, Jul 29, 2018.
  1. Jul 30, 2018 at 12:57 PM
    bwawuz02
    bwawuz02 [OP] Well-Known Member
    I'm pretty sure the Land Cruiser 100 series (2003-2009) came with a reverse cut 4.10 gear up front, which also uses the right size bolts for the FRS torsen carrier.
    TireFire likes this.
  2. Jul 30, 2018 at 1:00 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Just to verify, those circlip recesses are same distance in?
  3. Jul 30, 2018 at 1:01 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Yea. It’s the stock add from the t4r
    Can also use the fj tube that deletes the add
  4. Jul 30, 2018 at 1:02 PM
    05Taco4x4
    2TR-FE Enthusiast
    They are, I already looked... I'm just trying to verify they are "thin" gears like the 3.91 FJ has
  5. Jul 30, 2018 at 1:05 PM
    bwawuz02
    My only hold up at this point is figuring out the wiring and ecu setup from my current truck to function properly with the AWD t-case. Since my truck came with 4wd, the wiring harness is already in place and the switch for the e-locker (which my sport doesn't have) looks to be the same as the t-case locker switch in the T4R. I wasn't sure if I should use the 4wd ecu my truck came with, or swap out the T4R ecu, the plugs for both look identical. I know I will need the t-case harness though.
  6. Jul 30, 2018 at 1:08 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    This is cool! I live in seattle too and would love to lend a hand if needed.
    I want a torsen front diff too. Don't care for the AWD tho
    Lord Helmet and crashnburn80 like this.
  7. Jul 30, 2018 at 1:08 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    You’ll want the t4r computer and tcase wiring harness. The tcase has 2 shift motors. Therefor the plug is total different than a Tacoma case.
    The hi-low is one motor, then 2wd-awd-4wd is another motor
  8. Jul 30, 2018 at 1:09 PM
    bwawuz02
    I'm quite confident that the Land Cruiser gears are thin. If you look for aftermarket the 4.10 ratio is listed as "thick" and the others say they fit the 3.90+ carrier.
  9. Jul 30, 2018 at 1:10 PM
    TireFire
    Olympic Peninsula
    4wd Computer and ECU aren't the same thing, but should be next to each other.
    I think you know this, just clarifying...
  10. Jul 30, 2018 at 1:11 PM
    05Taco4x4
    2TR-FE Enthusiast
  11. Jul 30, 2018 at 1:12 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    Awd is worth it though. All the extra traction for rain/snow...
    A true torsen front and rear wound be sweet. Wound be nicer than the lsd rear that is worn out
    Lord Helmet likes this.
  12. Jul 30, 2018 at 1:12 PM
    bwawuz02
  13. Jul 30, 2018 at 1:13 PM
    YamaDirtrider
    Josh
    Elizabeth CO
    Correct. You only need the 4wd ecu. It’s got 2 plugs going into it. One goes to dash other goes to tcase.
    TireFire[QUOTED] likes this.
  14. Jul 30, 2018 at 1:14 PM
    bwawuz02
    This is exactly what I think I'll be going with, 3x torsen: front, t-case, and rear. I'm also interested in the added benefit of ridding my truck of any future drive-train vibration woes.
  15. Jul 30, 2018 at 1:14 PM
    #35
    05Taco4x4
    2TR-FE Enthusiast
  16. Jul 30, 2018 at 1:16 PM
    #36
    TireFire
    Olympic Peninsula
    Each to their own. I have a Harrop elocker in the rear and I quite enjoy locked 2wd sometimes
  17. Jul 30, 2018 at 1:16 PM
    #37
    YamaDirtrider
    Josh
    Elizabeth CO
    You can do the rear driveshaft with a double cardone joint without changing the tcase. I Shound have done it when I had mine built but dident and don’t have any vibes. Shound be around 2-3” of lift
  18. Jul 30, 2018 at 1:17 PM
    #38
    bwawuz02
    Well that is quite important then. I guess I'll have to find a land cruiser ring gear and confirm, but I'm pretty confident at this point that Toyota made things similar in dimensions to keep production numbers manageable.
  19. Jul 30, 2018 at 1:18 PM
    #39
    YamaDirtrider
    Josh
    Elizabeth CO
    Maybe I’m just salty that the clutch lsd is basicly gone and it’s no different than an open. And the fact that toyota dident offer a locker in the DCLB
  20. Jul 30, 2018 at 1:19 PM
    #40
    TireFire
    Olympic Peninsula
    Get a true trac. No clutches
