8.4 differential skid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Regcab05, Oct 21, 2014.
  1. Oct 21, 2014 at 2:13 PM
    Regcab05
    Regcab05 [OP] Well-Known Member
    David
    Atlanta
    05 regular cab 4x4
    Trail Gear 1/4 steel weld on. It's a nice piece, and cheap too $41.
  2. Oct 26, 2014 at 9:07 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Does it have a drain hole on the bottom? Would hate to have it collect water.
  3. Oct 27, 2014 at 6:14 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    It does have drain holes. Two triangle slits where it's bent at the bottom.
  4. Oct 27, 2014 at 8:10 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i dont think it even wraps around the bottom does it?
  5. Oct 27, 2014 at 8:32 AM
    Regcab05
    David
    Atlanta
    05 regular cab 4x4
    It doesn't, no loss in ground clearance.
  6. Oct 27, 2014 at 8:38 AM
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    if it doesnt wrap around the bottom how is this a skid? seeing as the bottom is the first thing to hit?
  7. Oct 27, 2014 at 8:52 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    It's more like a bash plate to protect the thinnest part of your housing. The under side is thick so you don't have to worry as much. I ran the BTF on my stock axle and it saved my ass countless times.
