8.75 diff
Discussion in 'Technical Chat' started by offroadtoyboy, Sep 23, 2022.
  1. Sep 23, 2022 at 7:17 AM
    offroadtoyboy
    offroadtoyboy [OP] Well-Known Member
    Middle of nowhere Cali
    2006 Pre-Runner / converted to full manual 4WD / RC62 swap / Manual 4R trasfer case mod
    I have read all the post about the 8.75 diff that comes in the 3rd Gen.
    I have read people saying that it has the same spline count as the 8.4.
    The bolt pattern for the 3rd member is the same from a 8.4 to an 8.75 using the same size studs.
    Can anyone confirm the diameter of the axle shaft at the splines is the same as an 8.4?
  2. Sep 24, 2022 at 6:16 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    The 8.75/8.8 uses 32 spline 1.37" axle shafts.
  3. Sep 24, 2022 at 7:07 AM
    offroadtoyboy
    Thank you
    Jowett likes this.
  4. Sep 24, 2022 at 8:11 AM
    Jowett
    Brian
    North Adams, MA
    Some 3rd gens come with the old 8" diff that have the 30 spline 1.31" shafts. Possible you can use the 8.75/8.8" housing, the 8.4 diff, and the 8" axle shafts with outer bearings etc?
  5. Sep 24, 2022 at 2:30 PM
    offroadtoyboy
    See that’s just it I had read the 8.75 and the 8.4 had the same spline count but different shaft size.
