8.8 swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by dogystiledx, Jul 5, 2017.
  1. Jul 5, 2017 at 2:21 PM
    dogystiledx
    dogystiledx [OP] Active Member
    parkersburg,WV
    2001 toyota tacoma sr5
    doetsch 3/4 drop 3in spring 4in blocks doetsch shocks costom cold air after market headlights and tail lights and roll pan an 18in dodge charger wheels on 225/40/r18
    I was thinking about doing a 8.8 rear end swap. I was wondering if this was a direct bolt in swap? I know you have to have the ford to Toyota adapter! I have a 7.5 rear end now but there isn't much selection for gears. My Tacoma it a 2wd with a 4in drop in the rear. I have 3 junk explorers so I already own the rear end. I'm getting ready to order flex-a-form rear spring and a hellwig sway bar for the rear just thought this would be a good swap.
  2. Jul 5, 2017 at 2:28 PM
    dogystiledx
    parkersburg,WV
    8.8 rear end not motor would never put a ford motor in a toyota
  3. Jul 5, 2017 at 2:30 PM
    dogystiledx
    parkersburg,WV
    lol It all good i see I really didn't specify
  4. Jul 5, 2017 at 3:51 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    Unless the leaf perches are the same distance apart, you also have to worry about brake lines, abs (if applicable), the emergency brake (both retrofitting to your system, and accommodating for the disc brakes), wheel lug pattern, and shock placement.
    What are your reasons for thinking it would be a good swap?
  5. Jul 5, 2017 at 5:19 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Because he's putting an 8.8 litre engine in!
    Honestly I wouldn't care if your engine was made by the Keebler Elves if you could stuff an engine that big in there :cool:
    Back to the real topic - what gear ratio do you want?
  6. Jul 5, 2017 at 6:17 PM
    Sjnbauto
    Sjnbauto New Member
    2001 Tacoma sr5
    3/4 drop
    4.11 gears I have 3.58s now
  7. Jul 5, 2017 at 6:18 PM
    dogystiledx
    parkersburg,WV
    ^that was me sorry lol
    Dalandser likes this.
  8. Jul 5, 2017 at 6:26 PM
    dogystiledx
    parkersburg,WV
    or 3.73s I have both gear ratios cause i have a few junk explorers
  9. Jul 5, 2017 at 6:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  10. Jul 5, 2017 at 6:37 PM
    dogystiledx
    parkersburg,WV
    thanks
  11. Jul 5, 2017 at 8:02 PM
    dogystiledx
    parkersburg,WV
    Quick question will a 1994 tacoma 3rd member fit my rear end
  12. Jul 5, 2017 at 9:08 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
    no. they didnt start making the tacoma until 1995.5. Before that they were just Toyota Pickups. Literally. That was the model. Pickup. Regardless, different rear end.
    I wouldnt bother with the swap, unless you are getting the gear ratio, and LSD. Otherwise it is hardly worth it.
  13. Jul 8, 2017 at 11:35 AM
    dogystiledx
    parkersburg,WV
    a buddy gave me the 3rd member out of his 94 has 4.1 gear ratio gears look good little slop in pinion bearing tho
