8.8" vs 8" locking rear diff
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RC84, Aug 25, 2015.
  1. Aug 26, 2015 at 7:23 AM
    cgalloni
    cgalloni Well-Known Member
    Understood, Thank you for the explanation
  2. Aug 26, 2015 at 9:34 AM
    AdventureKid
    AdventureKid Let's Go Places
    Jake
    Oceanside, CA
    17' DCSB TRD OR 4x4 6MT
    Camper Shell
    Stronger. I'm sticking with my order: '16 4x4 TRD Sport Manual Access Cab, throwing in arb rear locker + tons of goodies. Look for my build soon ;) thanks Jeff
  3. Aug 26, 2015 at 9:36 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Thanks for the clarification.
  4. Aug 26, 2015 at 9:45 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    +1 for not using "irregardless".
  5. Aug 26, 2015 at 10:26 AM
    RC84
    RC84 [OP] Well-Known Member
    3G Double Cab TRD OR
    SCS F5 - 17x8.5 Matte Gunmetal Cooper ST Maxx - 255.80.17
    The new 8.8 locking diff should be stronger than the 8.0 locking diff. Otherwise...why make the switch?
    The current 8.4 uses the same ring...8", as the 8" locking rear diff. It is, slightly stronger, from the info I'm gathering.
    In conclusion the new 8.8 locking diff should be an upgrade to what we currently have. Someone correct me if I'm wrong.
    Some folks are stating that the new 2016 8.8" is actually an 8"? Can someone confirm this or provide where they are getting this information?
  6. Aug 26, 2015 at 10:31 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    So we were told in MOAB from the Toyota engineers that the New 8.8 was the e locking diff :notsure:
  7. Aug 26, 2015 at 10:38 AM
    RC84
    All mannual trans models will come equipped with the 8.8 inch rear diff, but only the TRD off road will come with the elocker 8.8" in both auto and manual trans.
    Auto trans models in the 2016 lineup (non TRD OR) will come equipped with the 8.0" rear diff without the elocker.
  8. Aug 26, 2015 at 10:40 AM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Yea that's what in heard from them too. The actuator is inside the diff instead of outside as well. That might contribute to the larger size of the diff. Also they said it was available with 4.30 gear ratio...
  9. Aug 26, 2015 at 10:41 AM
    RC84
    That's what I'm reading as well. I believe the 4.30 gear is only available in manual transmission.
  10. Aug 26, 2015 at 11:26 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think Jeff wrote that its not but I think I am confused on this just like everybody else.
    I think simple question is this.
    Is Ring & pinion the same on 8.8 and 8.0 Differentials
    Yes /NO
    What is actual l diameter of Ring on 8.8 and 8.0 ?
    From what Jeff posted
    Diameter supposed to be different so it should be a different gear.
  11. Aug 26, 2015 at 12:02 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    The real question is are they reusing the current t100 axle, that would be awesome.
  12. Aug 26, 2015 at 1:15 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It doesn't seem like anything is really being reused.
    The "8.4" is an 8", the 8.0 is an 8". The 8.8 is an 8.8".
    The new e-locker uses an internal magnetic actuator instead if the motor-type on the older 8" e-locker.
    Jeff
  13. Aug 26, 2015 at 1:55 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Curious about the axle housing itself for 3rd member swaps.
  14. Aug 29, 2015 at 7:19 PM
    rtz
    rtz Member
  15. Aug 29, 2015 at 10:52 PM
    #35
    Jeff Lange
    Calgary, Canada
    Not sure, the manual states the BD22A[N] as 225mm/8.8".
    Jeff
    Hiluxski likes this.
  16. Aug 29, 2015 at 11:36 PM
    #36
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    My friend and I grenaded both of our 8.4" diffs. He has an automatic I've got a standard. They may be stronger but not unbreakable. Only with 33's on them.
  17. Sep 2, 2015 at 2:46 PM
    #37
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I think you are both correct and it seems common for the 8.75" and 8.8" to interchange for reference and I think the translation is slightly off in the metric conversion.
  18. Sep 2, 2015 at 3:23 PM
    #38
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The diff size is only as good as the gears & internals inside it.
    The question you should be asking........ What's the diameter of the axle shaft??? And has that been improved?
    The larger diff won't do shit for you if your axle shafts are pencils. ;)
    TDRsport likes this.
  19. Sep 2, 2015 at 3:52 PM
    #39
    Jeff Lange
    Calgary, Canada
    It should have larger axles as well, though I don't know the exact sizing obviously. That said, have axles been a weak point on the Tacoma's rear axle? I thought it had mostly been differential internals that had been causing issues.
    Jeff
  20. Sep 2, 2015 at 4:25 PM
    #40
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Axle shafts are good for 40s, only seen a few Tacoma rear axle shafts break you have to really try. The ring and pinion have always been the weak link in these trucks. Luckily just a few bolts and they can be swapped out. I believe the aftermarket gearsets are significantly stronger than the oem stuff though. It would have been nice if Toyota would have machined a load bolt to prevent deflection in the newer differentials though.
