8 bearings in TWO YEARS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hdf999, Jan 21, 2013.
  1. Jan 24, 2013 at 6:58 AM
    #41
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Why? Do you have experience with these situations?
    This is a typical crossing I would do with my truck. I venture deaper when other trucks are present so they can extract me.
    Maybe he does have other issues. Maybe his tie rods, LCA bushings, and LCA BJ's are also getting ready to go like mine did. Maybe they aren't.
    Crossing clean water should not be an issue unless the seals let water in. Both of my diffs and tranny fluid have always looked OK unless I drove to many miles without changing them....and even with that I have never seen any signs of water infiltration.
    Unless the clean water gets so high that it hits the fan and blows it apart or you suck water into the intake the majority of issues should be on wear parts (bearings/bushings/tie rods/etc. and electrical issues. After a while the electrical connections will corrode. For example my headlight bulb harness is bad even though I have cleaned it and applied dielectric grease.
  2. Jan 24, 2013 at 8:40 AM
    #42
    BamaToy1997
    Bill
    Navarre, FL
    Actually, a MECHANIC would be the type who would just replace the bearings and go. A good auto TECHNICIAN would go after the root problem...lol.
    Vehicles are built today to do some limited water crossing. 2-3 feet deep however is NOT a typical water crossing. At 3 feet of depth, the water pressure is 1.3psi. Not a lot, but these seals are rotating, and not designed, nor expected, to handle fording in 3 feet of water for 100 yards without some type of POSSIBLE intrusion. (I didn't say there WILL be, I said it is possible, and more probable at 3 feet. Heck that is half way up your doors!)
    Now we have the question as to why your bearings continue to fail. Well we would actually need more information. Are they failing because of lack of lubrication, improper installation, or water intrusion?
    Lubrication? Then perhaps the manufacturer has some problems, or the installer is not verifying that the bearings have proper amounts in them when installing.
    Improper Installation? You don't just throw these bearings into a press and go. There is a proper procedure to follow, and if you don't do it correctly, then you increase the risk of future failures.
    Water Intrusion? Were the seals replaced? ALL of the seals? you have 2 seals on the inside one that is in the steering spindle, and one that is on the axle shaft. Then you have 2 outer seals, one that is on the steering spindle, between that and the wheel spindle, and the other is the seal on the locking hub, or cap, depending on your system.
  3. Jan 24, 2013 at 10:02 AM
    #43
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Semantics! :p But yeah, we're on the same page.
  4. Jan 24, 2013 at 10:10 AM
    #44
    inouk
    inouk Well-Known Member
    Maybe dealer installed chinese-made bearings to save some bucks...
  5. Jan 24, 2013 at 11:01 AM
    #45
    BamaToy1997
    Bill
    Navarre, FL
    To some it is semantics!:p You are correct. To those of us who are professionals, it is more than that. I hate being called a mechanic. I hold myself to a higher standard in my work, and I have a hell of a lot more training and experience than a mechanic. But yes, I can see how you can see it as semantics in your eyes.
  6. Jan 24, 2013 at 11:06 AM
    #46
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Damn. Im about to break 100k and havnt touched mine
  7. Jan 24, 2013 at 11:46 AM
    #47
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Ouch!
  8. Jan 24, 2013 at 1:22 PM
    #48
    Tacoma Mike
    Southern Maine
    Thank You Bill..
  9. Jan 24, 2013 at 1:24 PM
    #49
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    My point is if the OP is running stock as he stated 2-3 foot water crossing and stock axle breathers can equal water in the diffs as well as water intrusion to the cab.
  10. Jan 24, 2013 at 2:41 PM
    #50
    BamaToy1997
    Bill
    Navarre, FL
    :oldglory:
  11. Jan 24, 2013 at 3:44 PM
    #51
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    This is probably not the cause, since they are going out on different wheels, but I'll put it out there so they can check the next time they pull the hub apart.
    Have them ensure the shafts are straight. I had a buddy who purchased a truck with two mysteriously bent halfshafts. They caused his vehicle to burn up wheel bearings - he replaced a boatload of them before an experienced tech decided to haul out the shafts, set them on a flat surface and spin them.
  12. Jan 24, 2013 at 3:53 PM
    #52
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    how big is your truck if the water is 3-4 feet deep???
  13. Jan 24, 2013 at 4:45 PM
    #53
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I'd get a unimog for this job meself. deep water daily ? shiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiit
  14. Jan 24, 2013 at 4:49 PM
    #54
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    have they replaced the inner seals when doing these bearing replacements?
  15. Jan 24, 2013 at 7:21 PM
    #55
    hdf999
    hdf999 [OP] Member
    05 Tacoma
    Thanks for the replies. Some seem surprised about crossing 2-3 feet of water daily. That is standard if you are in the timber/farming industry (I am surprised you were not aware of that).
    I am not sure on replacing the seals. Because the dealership has picked up the tab, I haven't argued details on the repairs, and assumed they would fix it considering it happens monthly.
    I am happy to hear that others aren't having this problem so hopefully I just got a lemon!
  16. Jan 24, 2013 at 7:32 PM
    #56
    hdf999
    hdf999 [OP] Member
    05 Tacoma
    Would it be bad etiquette to start a new thread about fording rivers, how often, and mechanical issues? Just hoping to learn about my problem.
    I am no car professional, just an owner and thinker and farmer.
    -Faust
  17. Jan 24, 2013 at 7:44 PM
    #57
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    I too am wondering if they are replacing the inner and outer seals for the bearing assemblies.
  18. Jan 25, 2013 at 12:32 AM
    #58
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Like a waste disposal technician!
    Don't worry though. I'm on track to soon be an entry level diesel technician.
  19. Jan 25, 2013 at 5:07 AM
    #59
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    It seems obvious, but next time start over, maybe with a new mechanic, and check all other moving parts, then make sure all seals inside and out are replaced with the new bearings. :confused:
  20. Jan 25, 2013 at 5:27 AM
    #60
    BamaToy1997
    Bill
    Navarre, FL
    I think maybe next time you start a thread, you try it with a little more tact in your posts. Several posts, similar to the bolded one above, are making you sound like a high-and-mighty who is better than everyone else. Not everyone here works where a 2-3 foot water crossing is the norm. I am in Alabama, and I have several customers with Tacoma trucks who work daily for a local logging company, and they have never said a word about 2-3 feet of water as a daily event. (or even a weekly event for that matter) I have replaced one set of bearings on each truck, and that has been it. Most of their trucks are 07 or 08 models, and are pushing 150-200k miles on them already.
    2-3 feet of water crossing is pretty deep, and to be honest, a Tacoma is pretty light of a truck to try and go into 2-3 feet. You must be having a lot of water in the cab every day. I just checked on one, and 3 feet is nearly half way up the door.
    Either way, perhaps since you were the one who posed a question in the thread, you could be a bit more polite in your postings. After all you were the one who asked for help and insight.
