8" lift options
Discussion in '1st Gen. Tacomas (1995-2004)' started by RGHRDR, Jan 7, 2024.
  1. Jan 7, 2024 at 2:30 PM
    RGHRDR
    RGHRDR [OP] Active Member
    Bobby
    99 Tacoma
    Ive completely redone the interior only thing left is the darn panels which other Taco owners have said i would have to repin master switches to install 2000 to 2004 panels
  2. Jan 7, 2024 at 2:31 PM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    If it's for your son then he'll appreciate the truck as is so he has a blank canvas to modify however he wishes in the future.
  3. Jan 7, 2024 at 3:05 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Yea anything above 3" of lift, unless solid axle swapped, pretty much ruins the truck. Leave it be, or throw some 2-3" lift coilovers on it and call it a day
    Ozark_RegCab and MadNachos like this.
  4. Jan 7, 2024 at 6:34 PM
    02hilux
    Planet: EARTH
    This is a cheap Amazon 6" lift....
    :argue:
    eortxz, Ricardo13x, Green1GT and 11 others like this.
  5. Jan 7, 2024 at 6:56 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Yep. At some point you need to know when to abandon the platform or get to doing serious fab.
    ControlCar and Ozark_RegCab like this.
  6. Jan 7, 2024 at 10:12 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    You’re not going to get much support here for a lift above 3” here unless you go for a solid front axle swap. The only way to do it while maintaining independent front suspension is with a drop bracket lift which is basically irreversible, and overall a pretty poor product. I believe some have been able to fit 35s on a 3” suspension lift, but it would require quite a bit of body work to not rub.
    beeboptaco and Ozark_RegCab like this.
  7. Jan 7, 2024 at 11:25 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    These 1st gens don’t do well with Drop Bracket lifts.
    If it’s for looks bro, get him a Chevy 1500, 6” lift on 35’s. Get an eBay Z71 sticker and the kid will get flashed daily. Ask me how I know.
    Oh, almost forgot, it has to be white.
    Ozark_RegCab and Koolbreeze7 like this.
  8. Jan 10, 2024 at 2:17 PM
    owenfri
    owenfri Member
    Owen
    2002 Silver Tacoma 4x4
    I added a 6-inch lift kit with a drop bracket from Rough Country. Without the drop bracket from RC or Fabtech, installing a lift would make the control arms have a steeper angle. But with the Rough Country kit, the angles are fixed, returning them to stock angles. Now, to improve the look further, you can use a 2-3" leveling kit on the 6-inch spacer provided by Rough Country to push the control arms back to an angle giving you about an 8-9" lift in total. Now I have a 3" body lift too so I have about 12 inches of lift clearing 35s with ease.
    The 35s now look small, the body lift was un needed but its funny being able to see the tops of f250s. I think a 8" and 35s would look sick on yours :)
  9. Jan 10, 2024 at 2:51 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    If you're going DB, I wouldn't run anything else but FabTech. RC is shady imo using nothing but BJ and coilover spacers to extend. FT will provide all new components including extended coilovers and massive spindles.
  10. Jan 10, 2024 at 4:28 PM
    RGHRDR
    Bobby
    99 Tacoma
    Thanks for all the advise and opinions to all that contributed. I will post pics as soon as the job is done. Thanks again
  11. Jan 10, 2024 at 4:30 PM
    v5ensx
    So what did you up with buying?
  12. Jan 10, 2024 at 4:37 PM
    RGHRDR
    Bobby
    99 Tacoma
    i think im about 95 percent sure ill be going with the Fab Tec
  13. Jan 10, 2024 at 5:07 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Probably the best option for what you plan to do
  14. Jan 10, 2024 at 5:24 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Now THAT is a truck!
    02hilux[QUOTED] likes this.
  15. Jan 10, 2024 at 5:32 PM
    #35
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    Supercharged w/ 7th injector 97 ECU swap 2001 front end swap TRD e-locker rear end swap 6 inch crossmember lift stretched to 11.5” 3 inch body lift 14.5” total lift
    I’m gonna disagree with that. I’m running a stretch lift. With no custom driveshafts.
    1 inch diff drop stacked on an 6 inch rough country diff drop. 11 inch extended coil overs and a 3 inch body lift.
    I’m not sure why people are complaining saying that there could be stability issues. This truck does donuts regularly.
  16. Jan 10, 2024 at 5:36 PM
    #36
    DemApples
    DemApples Kainoa HI
    Kainoa
    Kailua-Kona, HI
    1995.5 Tacoma
    If you plan on romping on your truck after doing a stretch lift I would recommend gusseting your spindles and get a good set of leaf springs instead of getting ridiculously huge lift blocks.
  17. Jan 10, 2024 at 6:00 PM
    #37
    RGHRDR
    Bobby
    99 Tacoma
    Like i mentioned earlier, im lifting the truck not to do any crazy off roading, but just to make it look a better and to pass it down to my son.
  18. Jan 10, 2024 at 8:08 PM
    #38
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Not to mention any IFS lift over 3" just looks cringeworthy. I honestly can't tell if OP is trolling or not.
  19. Jan 11, 2024 at 5:08 AM
    #39
    surfishjoe
    surfishjoe Well-Known Member
    Joe
    Margate, NJ
    2004 Double cab TRD
    Just for reference I run 1.5” and clear skinny 35s so not sure why you want to lift 8”.
    Ozark_RegCab likes this.
  20. Jan 11, 2024 at 5:37 AM
    #40
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Different strokes for different folks.
