80,000 mile 3.4 piston slap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trooperbearden, Jan 16, 2024.
  1. Jan 16, 2024 at 11:38 AM
    Trooperbearden
    Trooperbearden [OP] Well-Known Member
    Trooper Bearden
    01 xtracab 4x4 taco
    has anyone had a 3.4 with piston slap? as its gotten colder here the coldstarts with my 3.4 have been getting rougher. it runs pretty crappy when its cold then gets better as it heats up. The engine has a tapping noise that you can hear in the oilpan when its warming up that causes me concern. It goes away entirely when the car is up to operating temp but is present when its cold unloaded and loaded. in my experience rod knock gets worse as the engine gets hotter, but in this case it goes away entirely. any thoughts?
  2. Jan 16, 2024 at 12:39 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    My truck doesn't seem to like the cold much either. Are you sure it's not just valves tapping?
  3. Jan 16, 2024 at 1:22 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Post a video. Sure it isn't injector tick? Sometimes they sound like a sewing machine. Or slow morse code.
  4. Jan 16, 2024 at 3:51 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    If you've ever listened to a 1GR they sound like a diesel engine with the piston slap. I have had good luck using BG MOA to help remove alot of engine noise.
  5. Jan 16, 2024 at 7:17 PM
    Pentangler
    Pentangler 24 Aces
    2022 DCSB OR 4x4
    Previous Toys: 2021 DCLB OR 2017 DCSB SR5 2006 RAV4
    Curious as to what this "BG MOA" is that you speak of?
  6. Jan 17, 2024 at 5:59 PM
    tacoman2001$
  7. Jan 18, 2024 at 1:02 AM
    Trooperbearden
    Trooper Bearden
    01 xtracab 4x4 taco
    the issue is that you cant really hear it on a video or outside of the cab, but if you listen with a stethoscope on the oilpan you can hear tictictictictictic until it warms all the way up. after it warms up it sounds pretty good. one of the bearings on my timing belt is shitting the bed slowly so im wondering if im hearing the timing belt bearing and not the bearings. I did an oil sample test last oil change and it came back pretty good and i dont see a crazy amount of sparkles when i look at the oil so its a complete mystery to me. it gets good power and gas mileage just has that god forsaken noise when it cold starts
  8. Jan 18, 2024 at 1:07 AM
    Trooperbearden
    Trooper Bearden
    01 xtracab 4x4 taco
    it might be, but im not sure. would you be able to hear the valves in the oil pan? . im thinking that the noise is just reverberating from elsewhere since the oilpan is thin metal. you cant hear it on the side of the engine or anywhere else, even right next to the crankshaft under the air conditioning compressor.
    Ozark_RegCab[QUOTED] likes this.
  9. Jan 18, 2024 at 6:18 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    You should try a compression test. If it's piston slap you'd think you'd have lost a decent bit of compression.
  10. Jan 18, 2024 at 12:31 PM
    Trooperbearden
    Trooper Bearden
    01 xtracab 4x4 taco
    Thats a good point, ill do a leakdown test and see how it does
