802.11 n to g or B
Discussion in 'Technology' started by coffeesnob, Feb 9, 2011.
  1. Feb 9, 2011 at 3:22 AM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Is there any way to change settings to make a wireless N card into a g or b? The reason I am asking this dumb question is because verizon and virgin mobile mifi's are only compatible with the g and b cards. I have N cards, another question is are there any usb type cards where I could diasble the n and plug the other type card in the usb port and connect from it? Any suggestions? Thanks
  2. Feb 9, 2011 at 3:26 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  3. Feb 9, 2011 at 9:57 AM
    asphaltpilot
    asphaltpilot CAPS CAPS CAPS!
    South Florida
    PreRunner SR5
    Most N cards are already compatible to transmit in a/b/g. Are you sure it doesn't?
  4. Feb 9, 2011 at 10:55 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I was thinkin this too. Should be able to go in and change the flava somewhere.
  5. Feb 9, 2011 at 3:36 PM
    coffeesnob
    VA
    I don't know how to check, my skills are limited to turn the computer on and hit mozzila, but anyways I am moving to a rural area where my options will be dial up or mobile wifi. I read the system requirements and it says (because it only transmits in 3g) that you need a b or g card in order to receive the signal from the mifi box. I just hate to sign up for the service and then realize I need to buy something else...
  6. Feb 9, 2011 at 3:37 PM
    coffeesnob
    VA
    I don't need mine to transmit but to receive.
  7. Feb 9, 2011 at 3:50 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    Seriously, an 802.11 N card will transmit and recieve 802.11 A,B,G and N.
    I see however that you mentioned 3g which is an entirely different communication standard than 802.11.
    802.11 is generally used when connecting to a LAN. A wireless home router, which is connected to a DSL or Cable modem will allow for 802.11 connectivity.
    3g or 4g are standards for cell phone connectivity. Iphones, blacberry's or droids employ this communication to connect to cell towers and tranmit or recieve data. Also, you can purchase a 3g/4g card that allows you to connect a laptop or PC to connect to the internet.
    Hope this helps.
  8. Feb 9, 2011 at 3:59 PM
    coffeesnob
    VA
    thanks, this is what I have intel wifi link 5100 agn
    if you go to verizon, sprint, or virgin mobile and check out the mifi site, it says you need a 802.11 b or g card because the signal to it is 3 G I guess you receive the internet signal the same way you receive a cell phone signal, right?
  9. Feb 11, 2011 at 9:04 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    It would be automatic. The access point usually controls which standard is transmitted.
    No, you need both. Not getting into details, the basic jist is that your network card transmits a request and the access point receives, which more or less keeps going up the chain until your information is found and comes back your way, at which point the network card receives.
    DON'T ASSUME.
    Many cards leave off 802.11/A. You typically don't have to worry because an A network is very rare. This is because A was expensive,didn't transmit very well, and is incompatible with other formats. If you had an A network, it would be the first I've seen.
    On D-Link cards, their upper end N cards are dropping B support.
    OP, you should be OK with what you have. Worst case is it doesn't work and you drive to the store for something new. Note that it may also be beneficial to check into any DSL service that may operate in the area, which might be a cheaper solution.
  10. Feb 11, 2011 at 4:28 PM
    coffeesnob
    VA
    dsl is available but it is on a first come first serve basis. the guy who owns the house i am buying has it and you would think i would get his connection but it doesn't work that way, you have to be put on a waiting list regardless. If he were to cancel his service today and tommorow he changed his mind they would tell him he has to wait until his name came back up
  11. Feb 12, 2011 at 5:20 AM
    coffeesnob
    VA
    Anybody use netstat? I need to know if there results are accurate or not..It seems like it might be what little time I have had it downloaded
  12. Feb 12, 2011 at 6:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes it was fairly accurate for me- I used it (and a few other programs) for baseline comparisons and network testing and it worked just fine.
