8020 Cabinet Construction
Discussion in 'Vagabond Outdoors' started by JerryW, Aug 30, 2019.
  1. Nov 22, 2019 at 7:28 AM
    Wackyhacky
    Wackyhacky A Well Known Troublemaker
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    This excellent craftsmanship & inspiration! Looks great @JerryW.
    JerryW[OP] likes this.
  2. Nov 22, 2019 at 10:45 AM
    JerryW
    JerryW [OP] Well-Known Member
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    Thanks. I made the bug screen. It is a magnetic separating type I found at Walmart. It was for a single size door so I sewed some extra material on both sides to make it wide enough. Then I cut it to the shape of the rear opening and sewed Velcro around it. I used self-adhesive Velcro around the rear opening so it's easy to put up or take down when not needed.
  3. Dec 15, 2019 at 4:51 PM
    tielur
    tielur Well-Known Member
    Tyler
    Arizona
    2019 Cement Tacoma DCSB Off-Road
    Looks awesome! Do you have any photos of the base plate construction and how you attach to it? That's the part I'm struggling with the most right now. How to do a base plate and how to attach fridge slides, cabinets, ect.. to it.
  4. Dec 15, 2019 at 5:29 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    https://www.youtube.com/watch?v=HVfkxJiqLkA
    tielur[QUOTED] likes this.
  5. Dec 15, 2019 at 5:54 PM
    tielur
    Tyler
    Arizona
    Ahhh tnuts okay awesome, thank you for that. I assume you used the factory holes in the bed to secure the floor?
  6. Dec 16, 2019 at 5:21 AM
    Wackyhacky
    Keith
    Berthoud, CO
    2013 Tacoma DCSB
    Yeah, I think most who went the DIY baseplate method are using the factory bed mounting bolts/holes. If you go w/ 1/2" thick plywood the factory bolts are plenty long enough. I have a few pics/information on how I did mine on my build thread below. I am only using the front 4 bed mounting points to secure my baseplate & it has been fine.
  7. Feb 18, 2020 at 3:39 AM
    tielur
    Tyler
    Arizona
    @JerryW what is your base plate made out of?
    rockymtnbushwacker likes this.
  8. Feb 18, 2020 at 4:48 AM
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    It's 1/4" 5-ply plywood glued over 1/2" foam insulation.
  9. Feb 20, 2020 at 6:56 PM
    jimlangfordphotography
    jimlangfordphotography Well-Known Member
    2020 TRD OR LB
    1) How's the velcro holding up?
    (I was thinking snaps as I have had velcro come loose after thermal cycling.)
    2) Have you insulated/carpeted the remaining bare aluminum around the edges?
    (I was thinking that with the insulation kit there seemed to be many sections that are not insulated and would be cold to the touch.)
    Would love to see more photos on any new mods.
    Thanks
  10. Feb 21, 2020 at 5:42 AM
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    The Velcro is working great. I've had the screens in and out several times and it's solid. I don't foresee any trouble.
    I haven't covered the remaining bare aluminum. It gets cold but it's not a problem for me.
    No new mods. I'm at the end of a month long trip to Florida to escape the worst of the Midwest winter. I've spent almost 40 nights in the Drifter and I'm very pleased with this setup.
  11. Mar 20, 2020 at 9:00 PM
    _exped_
    _exped_ Active Member
    Paul
    Northern CA
    Any chance you would know the name of blue arrow? I'm trying to scour the sites you've mentioned and having no luck.
  12. Mar 21, 2020 at 8:26 AM
    alldownhill
    alldownhill Well-Known Member
    I'm not sure what was used here; it's likely you can buy individual fittings.
    But, you can just buy a stick of aluminum square tubing and cut to whatever length fitting you want. Drill 2 holes for the bolts. Done.
  13. Mar 21, 2020 at 9:25 AM
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    Yes, it's described right above the photo in the post you quoted. Often during these kind of projects you have to do a little custom fabrication.
    Anderson likes this.
  14. Nov 2, 2020 at 1:53 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    where did you get this tool?
  15. Nov 2, 2020 at 3:10 PM
    #35
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    The tap wrench and thread tap are available at any hardware or farm store(Lowes, Home Depot, Fleet Farm, etc.) or I'm sure Amazon has them.
  16. Nov 2, 2020 at 3:17 PM
    #36
    2020 TRD OR LB
    Did I see you sold your truck and camper?
  17. Nov 2, 2020 at 4:37 PM
    #37
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    I sold the camper and interior build but I still have the truck, although it will be going soon too. I'm changing things up a bit.
  18. Nov 3, 2020 at 11:25 AM
    #38
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    How many miles on the truck?
  19. Nov 3, 2020 at 11:42 AM
    #39
    JerryW
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    Only 58,000 miles!
    kalieaire[QUOTED] and rob1208 like this.
  20. Dec 11, 2020 at 9:52 AM
    #40
    gnardoggie
    gnardoggie Well-Known Member
    Do you have a BOM for your build by chance?
    nudavinci64 likes this.
