8020 Cabinet Construction
Discussion in 'Vagabond Outdoors' started by JerryW, Aug 30, 2019.
  1. Dec 2, 2021 at 4:28 AM
    #61
    JerryW
    JerryW [OP] Well-Known Member
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    In post #12, where the picture is, I described that part. Just a piece of square aluminum tubing with some holes drilled in it. The tubing can be found at Lowes or Home Depot.
    Often, these projects require a little bit of custom fabrication to fit your particular needs.
    gnardoggie likes this.
  2. Dec 2, 2021 at 7:36 AM
    #62
    manewsom
    manewsom New Member
    Wow, thanks for the time to respond. I figured it was fabricated. My project will require the same.
  3. Dec 2, 2021 at 8:13 AM
    #63
    gnardoggie
    gnardoggie Well-Known Member
    I used just small spans of 8020 with angle brackets and the bedrail T-nuts as well.
