(805) TW Members Thread
Discussion in 'Southern California' started by jblaze805, Feb 25, 2011.
  1. Jun 23, 2016 at 6:19 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    thats no Bueno man
    Get back at them by going to Rowher Flats with me on Saturday.
    doreydeluxe likes this.
  2. Jun 23, 2016 at 6:19 PM
    ntydog13
    ntydog13 Well-Known Member
    Alex
    Santa Barbara
    86 4x4 long travel pick up
    Lc engineering power pack, total chaos gen 2 caddy kit, 2.5 race runners, deaver f67, total chaos 12in shackles, king 2.5 double bypasses, corbeau baja ss fixed back seats
    OK so why do u think you wouldn't be able to use an impact on your lug nuts? U realize as techs don't just sit there hammering the lug nuts on they use a gun just to snug up the lug nuts then torque them with a torque wrench. I'm not completely familiar with second gens but I'm going to assume you have an automatic? Don't the second gens have a sealed trans that u can't check the fluid level? Could be wrong on this. Also my guess as to why they didn't check the transfer case and differentials is that it isn't on the list of things to check on a 20k service and the service writer probably forgot to add it to the repair order . Brake pads I'll agree with you on. Rotating in the spare in is a very very uncommon practice and I personally think is a bit overkill because you will always have one tire that doesn't have the same wear as the others possibly causing a pull . And no they wouldn't balance the tire before rotating it in . Do they balance all 4 every time you rotate? No. So why would you expect them to balance the spare. It's assumed that it was balanced when mounted. And taking 40 min to rotate a tire. Well you came back and the techs were probably busy working on other cars that had to be done as well and it probably just took them time to get a tech free to work on your vehicle .
    tritip and Motomon like this.
  3. Jun 23, 2016 at 6:22 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Make sure you explain all this when you go back in!
    This is why I only get my oil changed there (only because I got a shit ton for free when I bought the truck) I don't even let them look at anything else. Shit, they can even rotate my tires cause they don't have the OEM lug nut tool for my lugs. How fucked is that!? They're TOYOTA lug nuts! o_O
    I feel your pain man!
    veronatii likes this.
  4. Jun 23, 2016 at 6:27 PM
    ntydog13
    Alex
    Santa Barbara
    Oem lug nuts? Are you talking about the wheel lock? Or do u have splined lug nut?
  5. Jun 23, 2016 at 6:28 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Doesn't matter. If he said to check and they agreed then it should have been done. They can check all of those fluids.to send it off without the tires properly balanced is retarded. Also I would be pissed that they listened to NONE of his requests
  6. Jun 23, 2016 at 6:33 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Yeah Trans is sealed. Which was weird when I first found out. I don't recall checking any of those fluids on the standard 20k service either....
    I stopped trusting them after they lost a lug and tried to blame me, and left this in aftet an oil change:
  7. Jun 23, 2016 at 6:34 PM
    ntydog13
    Alex
    Santa Barbara
    Well if you were going to swap on a spare would you assume it's balanced or unbalanced. And I agree it's unfortunate that the fluids didn't get checked. The service writer was probably busy just like we all get busy and forgot to add it on to the repair order . Basically the missed services comes down to the service writer
  8. Jun 23, 2016 at 6:34 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Splined/locking lugs. Not sure what they are technically called, but they are straight from the factory. Its just weird they don't have the tools for Toyota parts :notsure:
  9. Jun 23, 2016 at 6:35 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    This ^! If it's not on the paperwork, it doesn't get done!
    tritip likes this.
  10. Jun 23, 2016 at 6:40 PM
    ntydog13
    Alex
    Santa Barbara
    Ya that happens from time to time forgetting the containers . At least they were trying to keep your engine bay clean instead of just letting it just fall all over the place . It comes down to the fact that the dealerships do see a very high volume of cars every day and they are constantly rushings techs to get cars in and out to try to accommodate the volume.
  11. Jun 23, 2016 at 6:45 PM
    ntydog13
    Alex
    Santa Barbara
    Are they all the same lug nuts or is there just one that is different than the others? If it's just the one then it's kinda understandable. That's a wheel lock. They all have a unique key and who knows how many different patterns there are so kinda hard for them to keep every pattern and then go through all those patterns to figure out which is your?
  12. Jun 23, 2016 at 6:46 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    I understand that, and that's why I always keep it simple for them. But still....that's not really an excuse.
    Does your buddy still work there? I always see his runner there.
  13. Jun 23, 2016 at 6:49 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    No its a standard yota part. One is keyed and all others are splined. It's funny, the same time they lost a lug Shawn lost the tool I let him borrow. So he had to buy a full set. They ended up giving me a replacement lug from the full set Shawn bought. So in reality, I still got jipped a lug nut :rofl:
  14. Jun 23, 2016 at 6:51 PM
    ntydog13
    Alex
    Santa Barbara
    Don't u have the tool yourself to be able to remove the tire? Or have u just not been rotating your tire?
    Ya he still works there .He's a line tech now. Actually have a few friends that work there .And let me tell you they are the happiest there either. It's all the owners and managers mind set there that's makes a lot of the techs unhappy
  15. Jun 23, 2016 at 6:58 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Of course I have the tool! Haha. They always had to borrow it to rotate my tires! Of course I rotate my tires. After the 2nd time they asked where my tool was to take the tires off I've always told them not to touch them. It's funny too, cause they still call me every time asking where my tool is to rotate my tires and I still have to tell them it's not needed. Again, it comes down to the fact that they don't listen or put it on the paperwork. Haha
    fishfinder and anthony250f like this.
  16. Jun 23, 2016 at 7:22 PM
    ntydog13
    Alex
    Santa Barbara
    Ya I'll tell u it's not just you .It is common practice to use to customers wheel lock. It would be like expecting them to have the key to your ignition .Could they have one of the who knows how many combinations sure but is it feesable
  17. Jun 23, 2016 at 7:30 PM
    Motomon
    Motomon Woof
    Central Coast, CA
    stuff and things
    It's not just Toyota. This happens at every brand...
  18. Jun 23, 2016 at 7:34 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    That was my point, they aren't special. They are an off the shelf tool that is made and supplied by Toyota. You could call them right now and order them, and they'd work on my lugs. Which is why it's insane that they don't have them.
  19. Jun 23, 2016 at 7:36 PM
    anthony250f
    Anthony
    San Diego, CA
    agreed
  20. Jun 23, 2016 at 7:40 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Just cause everyone's doing it doesn't mean it's right , man. :p
