(805) TW Members Thread
Discussion in 'Southern California' started by jblaze805, Feb 25, 2011.
  1. Apr 14, 2014 at 2:37 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Odd question...
    If I don't want to put more preload on the drivers side Icon coilover, what can I use to offset that "Taco Lean"?
    T
  2. Apr 14, 2014 at 3:04 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    You guys think I should tell him to look into pre gen1s too or stick with gen1? He's looking for more of a mountain/trail rig than a desert/pismo rig.
  3. Apr 14, 2014 at 3:18 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    that would be a good truck for pismo and anything really
  4. Apr 14, 2014 at 3:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Move the battery to the passenger side and a replace your gas tank with a centered fuel cell.
  5. Apr 14, 2014 at 3:27 PM
    anthony250f
    Anthony
    San Diego, CA
    do this...much easier and more cost effective than adjusting the preload :p
    hahaha
  6. Apr 14, 2014 at 3:45 PM
    TacoBrah
    Sean
    I don't know if he wants sfa or not, gonna talk more with him soon.
    Theo I would get the COs on then see if it leans. I've read in the suspension section that the new coilovers may get rid of an existing lean.
  7. Apr 14, 2014 at 4:35 PM
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    :notsure: i ran compressor air in all the shocks, pumped in without a prefilter a few blocks from the ocean for almost a year. somehow i didn't have any problems with any rust or the like... :p :poking:
    now i run nitro because i can.. but anyways id be concerned with the 4x4 system since it sits so much.
    sounds like the guy should look for a solid axle though if he's not into the whole going fast thing anyways. i saved a ton of money by selling my build and buying one that was farther along for the same price. i looked at it through a microscope, compression testing and the whole 9 yards. sure there were a few things i found that i fixed myself, but saving thousands in parts alone worked well for me.
  8. Apr 14, 2014 at 4:40 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    That's a bit over the top for me...
  9. Apr 14, 2014 at 4:46 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I guess I'm just being too fussy. I saw a guy selling his Icons on TW and he had a small top plate spacer on the drivers side "to correct the taco lean". I know some people who run the full OME setup install a Trim Packer on the drivers side...
    I just wanted to do it right the first time around and not have to tinker with stuff for weeks after after the initial install due to me not doing my research is all.
  10. Apr 14, 2014 at 5:01 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Just add preload. That's what the adjustable collar is for. I'm not understanding the "tinkering." You put the coils on, adjust both sides to the ride height you want and you're done. :notsure:
    Adding a top plate spacer is just going to push the whole coilover down (which will in turn reduce uptravel while adding downtravel (not good considering icon's are limited to prevent overtravel). OME trim packer effectively does the same thing as adding preload to a coilover...it preloads the coil.
  11. Apr 14, 2014 at 5:51 PM
    TacoBrah
    Sean
    Got my trail bible in the mail today.
    5D6EDBAA-2177-4C20-AF5A-51B276862082-493_486954b998ee3e67c42029942d054d1603c03b8d.jpg
  12. Apr 14, 2014 at 6:25 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Even when you have Extended Travel Icons?
  13. Apr 14, 2014 at 7:07 PM
    TacoBrah
    Sean
    I took a measurement and my driver side is about 1/2" higher, which is my own fault, I did it with an empty gas tank and was hoping it would settle with driver weight + full tank.
  14. Apr 14, 2014 at 7:09 PM
    anthony250f
    Anthony
    San Diego, CA
    coilovers are adjustable for a reason....
    would be stupid to add a spacer
  15. Apr 14, 2014 at 7:25 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Yes...that would make it even worse. Extended travel shocks just have a shorter shaft spacer inside the shock that allows the shaft to droop farther out. They are also intended only for aftermarket UCA's as the factory UBJ will max out and bind on droop if used with extended travel shocks. Adding a top plate spacer would push the entire thing down even farther.
    Just adjust the coilovers.
  16. Apr 14, 2014 at 7:53 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Roger that.
  17. Apr 14, 2014 at 8:37 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  18. Apr 14, 2014 at 8:38 PM
    marintacoma
    marintacoma Well-Known Member
    Marin
    2004 white toyota tacoma 4x4 trd
    I got the same package in the mail today too! Checking out some of the easier trails first
  19. Apr 14, 2014 at 8:40 PM
    TacoBrah
    Sean
    What a coincidence. Let me know what you think looks good in there.
  20. Apr 14, 2014 at 9:51 PM
    TacoBrah
    Sean
    Whats with people listing their gen1s for 4k over bluebook on CL?
