81 Tube frame Trekker NOW ADDING TTB’s and 400HP
Discussion in 'Hilux' started by 81Trekker, Aug 25, 2019.
  1. Mar 27, 2022 at 1:44 PM
    #321
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Right, and thanks. I understand that much of it.
    Right, but isn't the axle beam being twisted at the pivot bushing ( where the axles tubes mount to the frame )as it cycles through the travel?
    I had a '90 Bronco when I was stationed at Pendleton, I would go on desert exploration trips quiet a bit. I was replacing a lot of the radius arm mount bushings and the beam pivot bushings because of the way the components would "bind" as the cycled. I wasn't going fast, just a lot of suspension movement.
  2. Mar 27, 2022 at 1:46 PM
    #322
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    Sweet floor!
  3. Mar 27, 2022 at 1:47 PM
    #323
    Yota X
    NW New Jersey
    1st gen
    Damn!!! Serious setup!!!!! Looks awesome!
  4. Mar 27, 2022 at 2:08 PM
    #324
    Yota X
    NW New Jersey
    1st gen
    Great dash choice! This is the most tasteful toyota build I have ever seen. The best year Toyota ever, best motor setup, absolutely amazing work, a crazy original vintagy quilted dash that breaks up the race perfectly! So well done man! Stunning!
    Yossarian, Crunch11b and MSN88longbed like this.
  5. Mar 27, 2022 at 6:55 PM
    #325
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Thanks man... and sorry to disappoint but that’s the old dash, the new one has been modernized just a little bit :)
  6. Mar 28, 2022 at 12:09 PM
    #326
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Yes the axle travels in an arc but if the beam isn't solidly mounted to the radius arm it would flop like a wet noodle. You could build a radius arm with 2 heim joints at the beam similar to when people put 2 heims on a ladder bar in the rear to prevent axle wrap.
  7. Mar 28, 2022 at 3:41 PM
    #327
    2ndhandTacoman
    Walter
    Maryland
    I get that, and thanks for explaining. I can't see where there is any "give" for the binding that happens when the axle beams are swinging up and down. On the OE setup, the rubber bushings at the radius arm mount could move in and out a little. There's a heim on this radius arm frame mount. Obviously 81 Trekker knows what he's doing or he wouldn't have designed it the way that he did, I'm just trying to wrap my head around it.
  8. Mar 28, 2022 at 4:42 PM
    #328
    81Trekker
    La Jolla SD
    Think about the radius arm and I beam as one piece similar to a lower control arm. The whole thing moves up and down together and doesn’t bind though out the travel because the i beam and radius arm are so long. The down side to TTB is the camber/caster change. The caster at full drop is 1 degree and goes all the way up to 18 degrees at full bump. Camber goes plus/minus a ton too. TTB are really strong and work amazing if you can look past the geometry changes
  9. Mar 28, 2022 at 7:47 PM
    #329
    2ndhandTacoman
    Walter
    Maryland
    Thanks for taking the time to explain it better for me, when I thought of it as a 1 piece LCA the concept clicked.. :cheers:
    dk_crew and Yota X like this.
  10. May 9, 2022 at 7:58 PM
    #330
    Yota X
    NW New Jersey
    1st gen
    fits the new setup! Mind blown! Great work!
  11. May 30, 2022 at 2:34 PM
    #331
    81Trekker
    La Jolla SD
    So I decided to completely redo the rear suspension, ended up with about 30” of travel and I tig welded it all like an idiot. Oh I also got my motor back, it’s now a 4.5l, 4l80 and atlas are in and mounted with ZERO room to spare and the truck is currently at RPM getting a full tig welded, stainless exhaust.
  12. May 30, 2022 at 2:35 PM
    #332
    81Trekker
    La Jolla SD
  13. May 30, 2022 at 2:36 PM
    #333
    81Trekker
    La Jolla SD
  14. May 31, 2022 at 2:56 PM
    #334
    Yota X
    NW New Jersey
    1st gen
    Sick! Can’t wait to see that exhaust. Are you going w/ 2.5 or 3”?
  15. Sep 15, 2022 at 10:39 AM
    #335
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    You going to reupholster your doorcards to match?
  16. Sep 15, 2022 at 11:10 AM
    #336
    81Trekker
    La Jolla SD
    Yes, carpet, door cards, headliner... fuk it, it’s only money :)
  17. Sep 15, 2022 at 12:01 PM
    #337
    81Trekker
    La Jolla SD
    Oh yeah, it works and is too fast
    Yossarian, Yota X, SH10151 and 13 others like this.
  18. Sep 15, 2022 at 12:16 PM
    #338
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Too fast? Is that such a thing?
    RoaminRoman and Slashaar like this.
  19. Sep 15, 2022 at 1:09 PM
    #339
    81Trekker
    La Jolla SD
    Come drive it and you can tell me
    01 dhrracer[QUOTED] and Slashaar like this.
  20. Sep 15, 2022 at 1:24 PM
    #340
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Slashaar likes this.
