848 miles in 36 hours. To much?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TinyBauman, Oct 17, 2011.
  1. Oct 17, 2011 at 6:33 AM
    TinyBauman
    TinyBauman [OP] Well-Known Member
    Tiny
    NJ-South
    11 Tacoma DC
    I took my 2011 dbl cab 4x4 of the lot friday around 6pm with 8mi. by early am today I punched out for the weekend with 848 miles.
    Is this to much? not that I have a choice in the matter but was curious if this is concidered extremely excessive? I drive all weekend almost exactly 50% highway and 50% stop and go every half mile.(stopping about 220 times)
    was curious if any new owners were pushing these numbers and if they noticed anything to look out for
    should I consider a sooner maintaince sched then the reccomended 5000 miles?
    any real mechanical changes help with mpgs? Sunday a gentle man a custom car shop told me an air intake and exhaust would have a noticeable effect? been finding mixed reviews on this one.
    How many post till I have a search option? I been searching through google but theres been allota poop to sort through.
    Thanks guys, sorry if repetitive.
  2. Oct 17, 2011 at 6:42 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    intake and exhaust wont make any difference at all. just give you a lighter pocket...
    I would say get a scangauge and monitor you instant mpg with that so that you are able to max your mpgs and learn when to coast, what speed/rpm's to cruise at to get the best mileage. Keep your tires inflated properly. I'd stick to the normal 5k oil changes but also think about switching to synthetic and also changes out the diferential fluid to synthetic.
    Just curious but why would you get a truck if you are driving this much?
  3. Oct 17, 2011 at 7:17 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    X2 its completly fine and that's not really that much I've went 1800 miles in 29 hours non stop.
  4. Oct 17, 2011 at 7:18 AM
    Natemx
    Natemx Active Member
    SoCal
    '09 5-lug
    Readylift for now. TC UCA's soon.
  5. Oct 17, 2011 at 7:18 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Welcome to TW from Orlando!
    As long as you varied your speeds and didn't coast at a steady speed for extended amounts of time, you are actually better off than most. I've always been told it's best to break-in the engine as quickly as you can, and to use a good mix of highway/city.
    Sounds like you will be just fine.
    I always recommend doing your first oil change around 1,000mi. After seeing some UOA's, it goes to show that a lot of gunk is indeed still in the engines after they come off the line at the factory.
    After that, 5,000mi OCI's should be fine. You might look into running full synthetic for a little bit better mileage and a longer OCI.
    As far as an air intake and exhaust goes, just as Zombie said, it won't matter. Depending on the exhaust, it may actually annoy the hell out of you given that you drive on the highway so much.
    Just stay on top of your preventative maintenance and you will be fine. Don't forget to operate the truck in 4x4 for at least 10mi/mo - you will need to do this off pavement, though.
    Good luck!
    Fink
  6. Oct 17, 2011 at 8:04 AM
    RogueLeader
    RogueLeader Well-Known Member
    Rod
    Las Vegas, NV
    2011 Tacoma Double Cab SR5 TRD
    I did 5400 miles in mine in June, Las Vegas to Memphis, Memphis to Ft. Lauderdale, and back the reverse direction. Taco did great. Heavy rains in Florida on the return trip, lots of construction on I-40. Had the oil changed before and after the trip. Truck had about 3300 miles on it before the trip.
  7. Oct 17, 2011 at 8:09 AM
    TreyTRD
    TreyTRD Well-Known Member
    Trey
    Tennessee
    16 T4R TEP and 13 FJ
    I took mine to north carolina with 1100 miles on it on a friday, got home sunday with 2900. No issues, don't plan to do that every weekend though. Lol Hwy driving isn't to bad on cars, its short term city driving that kills them. Sounds like yours is getting plenty of time to get to operating temp so I wouldn't worry about a thing.
  8. Oct 17, 2011 at 10:00 AM
    TinyBauman
    Tiny
    NJ-South
    11 Tacoma DC
    Thanks for the help guys, this is going to be a weekly routine give or take a few 100 miles.
    Zombie; for a lot of reasons really, i needed something bigger with 4 wheel drive to transport my daughter and to still be mobile in the snow. I place weekend open house signs for new homes and rental communties for a living, so needed the bed space to transport approx 300 signs. (last truck was 2 door 4cyl 2wd manual ford ranger 97 with 150,000 mi, Im 6'3 230 and my daughter is still in an infant seat)
    Instead of buying a second truck on a mediocre budget and having 2 possible headaches. I opted to go with 1 new vehicle. It is my family/work truck.
  9. Oct 17, 2011 at 10:11 AM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I took mine from Bellingham, Wa to New Orleans, La this past July over a 3 day period and had no problems at all.
  10. Oct 17, 2011 at 10:15 AM
    TinyBauman
    Tiny
    NJ-South
    11 Tacoma DC
    I dont think this weekend is going to kill it, I am more concerned with arising problems continuing at this pace for the life of the truck...... oh and i found search tool.
  11. Oct 17, 2011 at 10:18 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i agree with the others. if you're driving responsible and do your preventative maintenance you should be just as fine as any other driver, possibly better if you really go by the book on maintenance. . at my work we have salesman car that is an 05 camry. we just service it properly and it has i think 300,000 miles on it right now and never ran better.
  12. Oct 17, 2011 at 10:19 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    I drove from new mexico to central florida in 30 hours ( about 1900 miles ) and had no issues. Just keep up with your oil changes and clean air filters until you need to change more major fluids/parts
  13. Oct 17, 2011 at 10:20 AM
    Sje1124
    Sean
    Louisiana
    Just a few
    It shouldnt be a problem, i drive 80 miles to work every monday thru thursday and about 150 miles every friday one way and have yet to have any problems. As long as you take care of the scheduled maintenance everything will be fine.
  14. Oct 17, 2011 at 10:29 AM
    Fink
    Orlando, FL
    As long as you stay on top of your preventative maintenance items, you will be fine.
    If you want peace of mind, full synthetic fluids would be a good idea. This may also allow you to extend your OCI's. If you want to get really fancy, send a sample off to Blackstone Laboratories and have them tell you how much longer they think you can go.
    Fink
  15. Oct 17, 2011 at 10:30 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I drove 3,000 miles in 3 days in a 2002 4Runner with 33" tires. You're fine. ;)
    Just do your routine maintenance. :D
  16. Oct 17, 2011 at 10:33 AM
    TinyBauman
    Tiny
    NJ-South
    11 Tacoma DC
    yea im a def anal about maintance, i will be taking it to the dealer for the first 2 years of free service. Do you think they will give me a hard time about using synthetic if the do not already?
  17. Oct 17, 2011 at 10:40 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    I would think hard about who told you this would be beneficial.
  18. Oct 17, 2011 at 10:42 AM
    Fink
    Orlando, FL
    I doubt they will give you a hard time, but I have to assume they will make you pay for the difference.
    Fink
  19. Oct 17, 2011 at 10:48 AM
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    Does it really matter? You need a vehicle to do your job and it's going to get used, it's not like you can carry stuff around on a back of a mule. If you're doing regular maintenance and still kill it, then buy go another one.
  20. Oct 17, 2011 at 10:53 AM
    Fink
    Orlando, FL
    For most of us I think it does matter. If I knew there was something I could be doing to help my truck last longer or run better for minimal expense/hassle, you're damn right I'll do it. Full synthetic fluids, used oil analysis, etc...
    As much as I'd love to have the "it's just a truck, I'll buy another one if it dies" attitude...I just don't have the cashflow to justify that.
    Fink
