.85 setting: OME 885 vs Eibach
Discussion in 'Suspension' started by Zac808, Jul 25, 2012.
  1. Jul 25, 2012 at 12:23 AM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I recently installed a cap on the truck and it made the rear a lot more smoother. So now the front feels really stiff. I'm thinking of possibly changing up my coils. Currently running eibachs @ .85.
    Would the taller OME spring (1.75" w/588lbs rate) be a smoother ride than the Eibachs(1.6" w/620 lbs rate)???:confused::confused: They will both be preloaded at .85.
    I'm trying to get my front as close to 3" as possible with a smooth ride w/ out selling my first born for some coilovers.
  2. Jul 25, 2012 at 5:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Why would you preload the OME coils? They are taller than the Eibachs and will put you at the same amount of lift as your current setup when set to the 0 setting. To answer your question though, the lower spring rate should soften the ride up a bit.
  3. Jul 25, 2012 at 5:36 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    Ok here's another thought between the two lifts. i know OME with 885 springs can support say an aluminum relentless fab bumper and winch and not make the front droop much. my question is can the billies set at .85 and eibach coils do the same? or would they sag?
  4. Jul 25, 2012 at 5:38 AM
    Pugga
    Massachusetts
    The Eibachs are a strong coil. They'll support the weight fine but I don't know for how long. The older 885 coils would sag over time but OME changed their production process and the new 885x coils have better resistance to sagging. I don't know how Eibach coils are made so I can't say how long they'd stand up to the additional weight.
  5. Jul 25, 2012 at 5:48 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    k thanks pugga, still debating on which lift to run.
  6. Jul 25, 2012 at 5:54 AM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    After about 10months with the 5100 and 885 set up (stock bumper), the 885s settled abit as expected. Set the 5100s to the .85 setting and took me right back to the same height i had when i first installed them, which was about 3.25"
  7. Jul 25, 2012 at 7:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Are they the new " x " coils ? Mine haven't moved in over a year
  8. Jul 25, 2012 at 7:44 AM
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    I dont believe they are, but either way when I say sag, it wasnt really all that much at all. I think i went from maybe 3.25 to almost 3 exact
  9. Jul 25, 2012 at 10:17 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I would preload it cause according to wheelers its only 1.75".
  10. Jul 25, 2012 at 10:23 AM
    OZ-T
    Peter North
    British Columbia
    I got 2 1/2" of lift on my DCLB with 885's , no top spacer
  11. Jul 25, 2012 at 10:30 AM
    Pugga
    Massachusetts
    ^^This. The Wheeler's site is incredibly misleading with their OME stuff. On an unloaded, unarmored Tacoma, you'll get more than 1.75". You'll be a lot closer to 2.5"+ as OZ-T stated, 3" with the top plate spacers.
  12. Jul 25, 2012 at 10:51 AM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    so you over got 3 inches with just 5100s and 885s huh? I thought it only gave about 2.5 maybe 2.75. No spacers or anything added? Im about to just order 5100s if so and skip the more expensive nitros. I can get all 4 less than 2 nitros. And I dont offroad much at all.
    edit you must not have spacers cuz u put em at .85.......do you have UCAs?
  13. Jul 25, 2012 at 11:30 AM
    Pugga
    Massachusetts
    Keep in mind, he might have gained 3" over where he was pre-lift. If his original coils were shot and sagging badly, he might have gained 3" over his OEM setup but only be 2.5" over a stock Tacoma. It's all relative.
  14. Jul 25, 2012 at 12:02 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Is that with OME shocks? Are the spring perches at different heights between OME and billies@0?
  15. Jul 25, 2012 at 12:05 PM
    Pugga
    Massachusetts
    Spring perches are the same between Nitrochargers and Billies at 0. I believe OZ is running Nitrochargers though.
  16. Jul 25, 2012 at 12:28 PM
    OZ-T
    Peter North
    British Columbia
    Yep
    Hasn't moved at all in over a year
    DCLB 4x4
  17. Jul 25, 2012 at 2:00 PM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    So you guys are saying if I put 885 OME front coils on my 5100's, and set it at 0, I should have 2.5" of lift? That would be nice, and I'm guessing a sick ride still
  18. Jul 25, 2012 at 2:32 PM
    Pugga
    Massachusetts
    Your reading comprehension is impeccable :thumbsup:
  19. Jul 25, 2012 at 2:38 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I would be mad at the sarcasm, but it was needed lol
  20. Jul 25, 2012 at 2:40 PM
    Pugga
    Massachusetts
    Sorry, I couldn't resist :D
