85 suspension revisted
Discussion in 'Toyota Trucks & SUVs' started by Arctic Taco, Jul 31, 2014.
  1. Jul 31, 2014 at 11:14 AM
    Arctic Taco
    Arctic Taco [OP] Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Howdy all,
    This one is for the early crowd for sure.
    Background: the 85 had a classic case of draggy toyota butt so I figured I would build up the springs using a set I got of of a 79 3/4 ton SR5 that I used to have. last time I did this was on a 52 CJ2A, so using Doug's maxim of cost effective spring work- shallow pockets- It began.
    Unfortunately I don't have too many before photos:
    the first is post rattle can camo paint last year:
    the 2nd is after the dust settled
    the 3rd is after the rear leaves with 3 leaves added - it eventually became 4. I will post some photos when I get back up north.
    the 4th is classic gravel pad wrenching
    the 5th is the not quite finished spring pack, going to use the old ubolts for clamps
    Attached Thumbnails[​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Jan 11, 2015 at 9:40 PM
    Arctic Taco
    Denali Park, Alaska
    Found this photo from the beginning- hauled the 85 up the Alcan from Mt.
    I guess everything has to start somewhere...
  3. Aug 27, 2016 at 9:35 PM
    Arctic Taco
    Denali Park, Alaska
    The rattle can paint job didn't hold up too well so sanding and priming in increments, cab mostly as a flatbed is in the design stages.
  4. Oct 17, 2016 at 9:11 AM
    la0d0g
    running for the hills
    For crawling not hauling
    :popcorn: Always down to watch another 80s truck thread!
  5. Jan 17, 2017 at 9:16 AM
    Arctic Taco
    Denali Park, Alaska
    Thanks, this one will take a while, but I'm down to see it through. Might be looking at a swapping out the oil drinker for a 22RE next year. Too many rigs too little money.
