85 vs 87
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Happy Hooligan, Jul 20, 2022.
  1. Jul 20, 2022 at 10:07 PM
    Lcfj60
    Lcfj60 Active Member
    2022 Tacoma AC MT 4x4 TRD Sport
    Lower oxygen concentration (air/fuel ratio) has nothing to do with this. This is really an ignition timing issue. Octane is simply how resistant fuel is to detonation under compression. Because lower atmospheric pressure (aka high elevation) effectively raises the octane of all fuels, 85 octane at high altitude will perform similar to 87 octane at sea level. So unless the engine has high compression or forced induction, running cheaper 85 octane will be fine.
    walleye_slayer likes this.
  2. Jul 21, 2022 at 6:05 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Were at sea level to 3k'. Only E10 87 to 92
  3. Jul 21, 2022 at 9:48 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    toyota says use 87 or higher so i still would use 87 even at high altitude.
    zoo truck and cosmic65charlie like this.
  4. Jul 21, 2022 at 10:20 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    It's on the YouTube, it has to be real.
  5. Jul 21, 2022 at 10:21 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What about when the gas station doesnt have 87?
  6. Jul 21, 2022 at 10:26 AM
    eon_blue
    Azusa, CA
    85 (not to be confused with E85) is effectively 87 at altitude which is why you only see it sold in places at altitude. It will be fine.
  7. Jul 21, 2022 at 10:27 AM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I noticed that too when I drove thru Utah, I put 89 or whatever available that's >= 87
  8. Jul 21, 2022 at 10:37 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Carb vs Fuel injection, naturally aspirated vs forced induction isn’t really relevant. It’s more about the compression ratio. You can have a high compression naturally aspirated engine that requires a higher octane, same as you can have a lower compression ratio on a forced induction engine and run 85 octane with out an issue. Most forced induction engines tend to run at a higher compression ratio, therefore requiring higher octane. Most, but not all.
  9. Jul 21, 2022 at 10:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    These new trucks all have exceptional knock control built in, you won't hear any knock, the computer will hear it far before you do and turn down ignition advance, but like everyone else said, 85 is available at an altitude where it is safe to run in place of 87. There will be no knock issues.
  10. Jul 21, 2022 at 10:40 AM
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    Even in that video he said it's fine to use 85 if you live up high and stay in the area, have a naturally aspirated engine and don't drive hard. So basically 85 is fine to use in the Tacoma high up.
  11. Jul 21, 2022 at 11:37 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    then i would use 89 or 91 or 93
  12. Jul 21, 2022 at 11:39 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Based on my experience with his videos and the fact that he used to be a mechanical engineer, I’m going to trust his opinion over the opinion of randos on an Internet forum.
    Did you watch the video? He doesn’t entirely disagree with those promoting the use of 85 octane. I think the title of the video is partly “click bait” and partly a reference to Ford’s published recommendations to not use 85 which he starts the video with.
  13. Jul 21, 2022 at 11:41 AM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    I used it for almost 10 years, the only concern I would have is if you plan on driving to lower elevations on a single tank.
  14. Jul 21, 2022 at 1:08 PM
    Chugiak76
    Chugiak76 Well-Known Member
    Colorado Springs, Colorado
    2020 Tacoma SR 2.7 4x2, AXC
    My 4 cylinder runs just fine on 85 octane. Running 85 or 86 in the V6 won't hurt anything, but it might make it suffer slightly from mpg and power loss if you use 85 for reasons that involve compression ratios and ignition timing.
  15. Jul 21, 2022 at 1:09 PM
    #35
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Watch it...
    You might learn something.
