~85000 miles, Engine Code P0011
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NO or NC, Oct 15, 2012.
  1. Oct 15, 2012 at 4:20 PM
    NO or NC
    NO or NC [OP] New Member
    Maine
    06 TRD
    My 06 Tacoma has about 85000 miles on it. I was pulling into a parking lot on Sunday, the engine shuddered as was pulling into the parking spot. I noticed the check engine light came on. I was late so i just turned the beast off and went inside. About an hour later i came out and opened the hood to see if i could notice a reason for said shuttering. (I had the ac compressor seize [fixed by pulling the relay that engages the compressor solenoid] on me last winter, the shudder i felt reminded me of that experience) I noticed nothing out of the ordinary, so i started the beast up, noticed the CEL is still on, but did not notice any noises or shuddering. I drove it to the dealer and left it there for them to look at today. They got back to me today with a $1500 estimate to replace a/the (?) VVTI cam. The engine was pulling a P0011 code. Am I being hoodwinked??? Is this a common problem for the mileage?? Help!
  2. Oct 15, 2012 at 4:24 PM
    98tacoma27
    98tacoma27 is gooder 'en chicken Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+250k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Your oil control valve filter maybe clogged or the valve maybe bad.
  3. Oct 15, 2012 at 4:25 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  4. Oct 15, 2012 at 4:48 PM
    NO or NC
    Maine
    06 TRD
    Thanks for the quick feedback, I'll check out the filter first.
  5. Oct 15, 2012 at 5:28 PM
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    Check the filter and replace if needed. I would also have the code cleared and continue to drive the truck if it seems like its OK. If it's something in the VVTI it will throw the code again and then you can decide to spend $1500 dollars.
    Bill
  6. Jul 18, 2013 at 1:06 PM
    pwo
    pwo Active Member
    Philip
    Northeast Arkansas
    RED!!! 07 4x4, trd sport
    JP Metal Fab Tie downs, Tacoma4x4 LED 4x4 switch, Weathertech mats, Ultra-gauge, Sony in dash DVD, LED cup-holders and cubbies.
    Please help, I am having the same issue as the OP, only mine is so bad that the truck is undrivable... Can anyone tell me where the VVTI filters are? I can't pics with locations of these.
  7. Jul 19, 2013 at 8:12 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Which code you have? Are you looking for Bank 1 (RH) or Bank 2 (LH) ? I can try taking picture when I get home.
    Basicly from outside they are single bolts, when you unscrew them there is filter underneath them.
  8. Jul 21, 2013 at 4:31 PM
    pwo
    pwo Active Member
    Philip
    Northeast Arkansas
    I am throwing codes: P0011, P0301, P0303, P0305.
    The P0011 is in constantly now and will not clear. When this all started last week it would clear and stay gone for a few hours but now it will not go away.
    The other codes only come in after the engine is warmed up and I am sitting at a stop sign or red light. Everything is associated with bank 1.
    I have changed plugs, changed oil, and replaced both cam sensors. I took my baby to the dealership and they don't have a clue, although they did quote me $2300.00 for them to replace a cam gear! I thought it was weird that they would tell me that they don't know what's wrong with it then the very next sentence out of their mouth was giving me a quote for a cam gear... As you can imagine I lost all faith I my local dealership.
    I also removed the VVT valves when I changed the cam sensors, but honestly I would not know if they were bad or not? They appeared to be in good working order...? I never saw a filter or screen of any sort. Are these in a different location?
    Thanks to anyone who responds, just need help .... I can't see speeding $2300 and the dealership told me that it still might not fix the problem.... I don't know... is there any merit to what they are telling me?
  9. Jul 22, 2013 at 4:39 AM
    NO or NC
    Maine
    06 TRD
    My problem turned out to be a faulty oil control valve. I had the cam replaced for 1800 and the problem came back 3 days later. They checked it over again and found that the oil control valve for that bank was working sporadically. I bitched up a storm and they covered half of my original cost. Good luck!
