85k miles…coolant flush or drain and fill?
Discussion in '4 Cylinder' started by IEsurfer, May 20, 2023.
  1. Jun 2, 2023 at 12:22 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    @knayrb is spot on. The last thing you want to do is risk mixing IAT and OAT coolants. In todays world you best know what you are putting in your car or truck. IAT is (ethylene glycol based) typically used in older cars and OAT (propylene glycol based) is a newer technology better suited for newer cars and is typically good for up to ~5 years. Mixing the two would likely result in a Jell-O like substance which could literally block you cooling system and cause extreme damage to engine internals.
  2. Jun 2, 2023 at 1:12 PM
    digcolnagos
    digcolnagos Member
    Agreed. Fortunately, my regular guy, whom I trust based on experience, can do it on Monday, in time for my upcoming long trip.
    69 Jim likes this.
  3. May 9, 2024 at 10:18 PM
    Mason502
    Mason502 Well-Known Member
    Mason
    Mount Sterling, Kentucky
    2015 Tacoma 4x4 Access Cab 2.7 Automatic
    Bilstein 5100 shocks, cali raised LED.
    Where is the coolant drain plug on the engine block for the 2.7?
  4. May 9, 2024 at 10:42 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
