86 toyota pickup, starting problems
Discussion in 'General Automotive' started by white toy taco, Apr 18, 2012.
  1. Apr 18, 2012 at 1:12 PM
    white toy taco
    white toy taco [OP] 505 Member
    Gian
    Albuquerque, NM
    02 4X4 Taco SR5 TRD V6
    All-Pro tube bumper, 5100's at middle setting w/OME 881's, rebuilt leafs w/ 2 chevy leafs, 265/75/16 Km2's, CloudyFab sliders, 6000k HID headlights (35w), 16" LED light bar,100w KC Daylighters,
    so i have an old 86 pickup that sits around and its real picky about when it wants to start. I charge up the battery (which is no more than a year old) and it starts up. then i go for a drive and stop somewhere for a few mins. when i come back to start it, it makes that "click" noise that it does when ther battery is dead, but the lights and everything work. then it will only start when i jump it.
    I just replaced the starter about 4 months ago so i know its not that and i replaced all the spark plugs also. What do you guys think? could it be a bad battery connection, bad alternator, or that i just dont drive it enough? Oh and the truck has a little less than 250K miles
  2. Apr 18, 2012 at 1:21 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    SAS see build stock T4R FJ40 just getting started or ending?
    Check the battery voltage? Lights will still turn on with ~6 volts normally and it normally takes above 10V for the starter motor..
    I would guess the alternator. Most NAPA and other auto parts store will test the battery and alternator if you bring them in for free... I would do that. GL
  3. Apr 18, 2012 at 1:59 PM
    white toy taco
    Gian
    Albuquerque, NM
    ok so take them off and bring them in?
  4. Apr 18, 2012 at 2:05 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    No need to remove any parts, just park close to the building and tell them you would like a test of your starting and charging system. They will eventually roll out a cart/dolly thing with some gear attached, this is their testing equipment which they will attach to your truck. You start the truck, they do the test and let you know what is up. Sometimes, they will ask you bring your battery inside the store for testing and/or charging... fortunately the battery can be removed quickly and easily. I have had good experience with this free service, especially if you don't let them sell you something that you don't really need. :D
    EDIT: This is in reference to what "NAPA and other parts stores" will do. Around my area, Kragen/Checker and AutoZone both have a dolly with equipment for checking electrical and systems while the parts are still installed on the vehicle. Just wanted to clarify.
  5. Apr 18, 2012 at 3:53 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    That is what is easiest for the shop and you normally...
  6. Apr 18, 2012 at 3:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    make sure the battery terminals are on tight and not corroded.
  7. Apr 18, 2012 at 9:31 PM
    white toy taco
    Gian
    Albuquerque, NM
    so i replaced the whole positive wire and sanded the paint off for the ground for better contact and everything works good so far.
    Thanks for your help guys!
  8. Apr 18, 2012 at 11:03 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2018 T4R & '95 SAS
    Glad you got her fixed!
  9. Apr 19, 2012 at 7:43 AM
    white toy taco
    Gian
    Albuquerque, NM
    Yea me too! It's actually been in the family for many years, it was my cousins first car back in the late 80's. I'll post up a pic when I get the chance
