87 Octane Gas: Minimum vs. Recommended, & Benefits (if any) of Higher Octane Gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MateoTorgy, May 6, 2016.
  1. May 6, 2016 at 3:38 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    This has been brought up before in the 3 million other "what octane..." threads. The early years had a line in the owners manual that said something like " for optimum performance use 91 octane" or something like that. I've never found or gotten any answer about why this was changed but imo if Toyota used to recommend higher octane it must have been for a reason.
    AR15xAR10[QUOTED] likes this.
  2. May 6, 2016 at 4:20 PM
    SoCalSteve
    SoCalSteve Sunshine Tax
    San Diego
    2017 F150 XLT
    Ran 87 octane for almost three years. Some pinging under certain conditions, but not a huge deal.
    Switched to 91 octane six months ago. Pinging disappeared and gained 1 MPG.
  3. May 6, 2016 at 4:31 PM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    You got an interesting case. No offense here but I got my first chance to try out ethanol free(they only had 87) in Florida before drove back to N.C. and yeah $.75 more/gal. I was excited because non where I live. I expected it would give me a better mpg, but it didn't. I got the same results as 87 with ethanol. Same distance same interstate(95). That's on my truck and my scanguage. The only different was driving day and night.
  4. May 6, 2016 at 4:34 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    There's an ECU reflash for your engine assuming it's a 4L. Take it to the dealer and ask for it.
    Norton and NMTrailRider[QUOTED] like this.
  5. May 6, 2016 at 4:35 PM
    digitaLbraVo
    I switched to 91 to stop pinging, and prefer how it runs. It feels better. I occasionally will throw in 89 during cold months but generally just roll 91 all the time. The cost difference is like $4 for a full tank, I'm not sweating that.
  6. May 6, 2016 at 5:13 PM
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    There was a Bulletin from Toyota about it for the FJs. Basically for the dealers to just "tell people 87 is fine"
    From what I gather they simply put to use premium because the vehicle was tested and numbers were published using said fuel. No reason the 4L shouldnt run the same around town. Not sure how many, if any, usable ponies 87 would make.
    Part of me thinks Toyota thought that it makes a car seem more niche and high performance with that sticker under the gas door.
  7. May 6, 2016 at 5:17 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Thanks for the heads-up. I wonder if they would have done the reflash at my 5/10/15k service without telling me? Will ask next time I go in.
  8. May 6, 2016 at 5:20 PM
    NMTrailRider
    New Mexico
    This has been my exact same experience (but I discovered it after about 3 months). FYI-- I gained nothing going from 91 to 93 (although I'm often forced to use it when the only options are 87/93).
  9. May 6, 2016 at 5:34 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If memory serves me the first few years of the 2nd gen required Premium and had a 245 HP rating.
    MateoTorgy[OP] likes this.
  10. May 6, 2016 at 5:46 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    You need to understand the definition of octane and cetane and the point of ignition. Then you need to understand what type of engine you have. Running a fuel that the octane is to high for your trucks engine can actually cause problems. Why do you think Ferrari's run 98 octane and your tacoma runs 89. A high performance engine needs a faster explosion in the cylinder. Where your slow moving tacoma doesn't. So regardless of everyone thinking that putting higher octane gas in there tacoma is making run a million times better is actually false. Your just throwing money away. If in fact you want your truck to run better try servicing your fuel system and run the recommended fuel that toyota says to run.
    Scott B. and MateoTorgy[OP] like this.
  11. May 6, 2016 at 5:46 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Yeah its one of those topics where half of people will tell you octane rating does not matter, others will tell you its miracle.
    IMHO, better octane means cleaner fuel, because to achieve higher octane fuel companies have to better distill the fuel.
    Also our trucks have enough compression and mapping to make use of higher octane, so if you drive to take advantage of it you will see an advantage.
    So in essence if you dont know how to take advantage of higher octane, dont waste your money on it, if you do, you probably know the answer which one is better.
  12. May 6, 2016 at 6:19 PM
    NMTrailRider
    New Mexico
    Same as my 2014 owners manual. And this makes me think... I can run 87 or higher. Fairly cut and dry.
    If I shouldn't be running 93 it seems like the manual would say 87 or higher but not more than 91.
  13. May 6, 2016 at 7:03 PM
    adamax
    adamax Well-Known Member
    adam
    springville ut
    2015 trd off road
    correct me if I'm wrong but altitude plays a role in octane requirements too.
    rivak, MateoTorgy[OP] and Norton like this.
  14. May 6, 2016 at 7:11 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Same as my 09
  15. May 6, 2016 at 7:36 PM
    #35
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    I know it's Wikipedia, but I seem to recall the latter numbers being published by Toyota when the 2nd Gen first came out and when they spec'd 91. IIRC, it was later spec'd for 87, but the output also dropped a bit.
    The 91 gives a torque bump and at a lower RPM as well.
    "Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane"
  16. May 6, 2016 at 8:20 PM
    #36
    digitaLbraVo
    It's possible. My pinging immediately went away and it was bad. I still run the premium though 'cause my fuel mileage is better and I feel like it runs nicer.
  17. May 6, 2016 at 8:46 PM
    #37
    Dea1276
    Dea1276 Active Member
    Vista CA.
    2011 TX/PRO
    OME 885 on 5100s, Dakar springs, b110 5100 rear, LR UCA, Wheeler's superbumps.
    Octane only changes the temperature of ignition. Higher octane is used when compression is higher to prevent pre-ignition before spark. Higher octane does not contain more energy. More power can be gained in variable timed engines when the computer senses a higher octane rating and allows compression to build slightly higher before spark. Whether the Tacoma does this or not I don't know.
    RJ_MacReady and MateoTorgy[OP] like this.
  18. May 6, 2016 at 10:33 PM
    #38
    NMTrailRider
    New Mexico
    My ping was never really that bad. Just on grades and and with a certain amount of pressure on the pedal. But I agree with you- I feel like it just runs a little better. I also notice it on off/on ramps on the interstate.
  19. May 6, 2016 at 11:04 PM
    #39
    Joey4x4
    Joey4x4 Member
    Joey
    Northern Michigan
    2014 Black Tacoma RC
    If the engine is VVT it should make a difference in how far it can advance timing... There will be two separate fuel and ignition timing maps to match the valve timing. Might not be much, but there is an advantage to it. I'm intimately more familiar with Honda's VTEC timing and fuel maps (turbo with Uberdata) than I am with Toyota's VVT setup. In conjunction with the knock sensor readings if there is no knock it can keep advancing ignition timing until it reaches its limit point. If there is knock (engine "ping") due to lower octane fuel usage the system will retard ignition timing giving you less than optimal power. Now if Toyota set it all up with 87 octane being the maximum spec, it won't matter at all, but I doubt that they would limit it to that fuel when 91/93 is available most places.
    IANAL and I didn't stay at Holiday Inn last night though...
  20. May 6, 2016 at 11:05 PM
    #40
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    +1, in at least 5 places.
    NMTrailRider likes this.
