87 suburban issues
Discussion in 'General Automotive' started by 95 taco, Apr 6, 2013.
  1. Apr 6, 2013 at 8:37 AM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    We have a 87 suburban with the 5.7 back here in MISS, and she's running rough, she doesn't want to idle and when it does idle the RPM's constantly rise and fall, after fluctuating a few times it dies.
    It also seems to be running rich, if I punch the gas in gear it might rev a little but if I let off the gas a little it will raise the RPM's to where they should be.
    It seems to rev fine in neutral and park, the water pump was replaced 3 (?) years ago, and it has a coolant leak where the bottom hose on the radiator meets the block.
    I'll add more info when I get to my computer (tonight)
    Any input is appreciated
    Edit: forgot to mention its fuel injected, and we replaced the injectors a few years ago
  2. Apr 6, 2013 at 5:37 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like a vaccum leak
  3. Apr 6, 2013 at 5:47 PM
    95 taco
    I'll have to check that tomorrow, thanks Doug.
  4. Apr 7, 2013 at 9:31 PM
    Speed Freek
    Speed Freek Turbo lover!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Check your Idle Air control valve, its probably sticking..
  5. Apr 7, 2013 at 9:35 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    this.
  6. Apr 7, 2013 at 9:45 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
  7. Apr 8, 2013 at 7:00 AM
    95 taco
    allright, thanks jason.
    if it's sticking do i just shoot it with carb cleaner?
    i pulled the air pump for the smog system since it wasn't hooked up, to plug it i'm gonna use a big bolt ( if we have one, if not then i'll make a wood plug), would it hurt anything to put some silicone on the threads to help seal it?
  8. Apr 8, 2013 at 10:38 AM
    95 taco
    i pulled the IAC valve and it looked like this
    i cleaned it with carb cleaner, and it looked cleaner, but i think it's stuck in the position, i reinstalled it, did the IAC reset, and it still runs funny.
    after lunch i'm gonna unhook the TPS and check for vacuum leaks.
  9. Apr 8, 2013 at 11:54 AM
    95 taco
    i haven't checked for vacuum leaks, but i did some reading and found out that i can test the IAC valve when it isn't in the TB, so i did and it didn't move at all so i'm assuming that that's the problem.
  10. Apr 8, 2013 at 1:36 PM
    95 taco
    Just took it for a drive with the valve removed, it will bog with anything over a very light touch of the pedal, until its revving pretty good (no tach, but it sounds about halfway to redline) , once you get it passed that point you can floor it and it will slowly and smoothly accelerate.
  11. Apr 8, 2013 at 1:43 PM
    95 taco
    Forgot to say that the idle smoothed out after it warmed up, but it was idling fast.
