87 Unleaded V.S 91/93 premium GAS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Azntrutek, Jun 26, 2013.
  1. Mar 21, 2015 at 2:48 PM
    #41
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Except at Petro-Canada or Husky. ;)
  2. Mar 21, 2015 at 2:49 PM
    #42
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I meant where I live , we don't have a Petro Can or Husky station here
  3. Mar 21, 2015 at 3:16 PM
    #43
    OZ-T
    Peter North
    British Columbia
  4. Mar 22, 2015 at 4:23 PM
    #44
    330d
    330d Active Member
    Caleb
    Upstate NY
    Shopping for it....
    And that's why I'll buy ethanol free. I don't care about anything except *uck the government for fixing a problem with a larger one. Also - knock reduction in my case seems to be a real thing with the 91 octane.
  5. Mar 22, 2015 at 7:30 PM
    #45
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Unless you are referring to ethanol free than you will not get improved mpgs and will spend more. I run 87 and got 21.1 on last 2 tanks.
  6. Mar 22, 2015 at 8:01 PM
    #46
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    My 4.0 pings on 87 Octane, nothing with the 93 Octane...I will personally stick with the 93
  7. Mar 22, 2015 at 8:04 PM
    #47
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Take to the dealer under warranty as your truck is rated for 87 from the factory.
  8. Mar 22, 2015 at 8:30 PM
    #48
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This is true. Here in my town in Montana we have a SINGLE fuel "dispensary". I've talked to a guy who actually sells the fuel (the regional guy who makes all the money) and a guy who fills all the fuel trucks that supply the gas stations. Both have told me the same. All the gas stations in our city get their fuel from this single location. However, each chain of gas stations adds it's own proprietary "additives" or "cleaners" to the gasoline.
    This is coming from horses mouth so to speak.
  9. Mar 22, 2015 at 11:39 PM
    #49
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    18.6 mpg with Mid grade 89
    19 mpg with Premium 93
  10. Mar 22, 2015 at 11:42 PM
    #50
    jandrews
    '09 FourDubDee TRD OR
    I've gotten significant differences in engine note and mpg using ethanol-free 89/93 vs other stuff. The factor that matters most seems to be whether there's corn juice in the gas or not.
    Most of the time I just run 87 anyway.
  11. Mar 23, 2015 at 11:02 AM
    #51
    jpachard
    jpachard Well-Known Member
    2006 4WD 4.0L Tacoma 6spd TRD
    It's not clear to me if Toyota did their validation of 87 octane fuel with or without ethanol. I know 87 octane with ethanol should perform the same as 87 without, in theory.
    Regards, James
  12. Mar 23, 2015 at 1:21 PM
    #52
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    I've started running 93 again for the past couple fill ups. Engine is much quieter and doesn't ping in that dreadful 2k-3k range upon light acceleration, and when going up slight inclines or hills the truck downshifts on its own without requiring much additional gas pedal input. With 87, its like the truck is asking "do you really expect for me to go up this hill at constant speed? well, ok, if you really want to, I guess I'll downshift then."
    I've said it before - over the lifttime of the truck, using 93 is one of the cheapest 'mods' you can do where you actually get performance benefit. It sure would be nice if someone would do a comparison on a dyno.
  13. Mar 23, 2015 at 1:27 PM
    #53
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Heres the real question.....
    How many of you replace your air filter every 10-30k miles or clean it if its reusable?
    How many of you clean your MAF sensor?
    How many of you actually clean your throttle body and internal butterfly?
    Doing this on a regular basis will yield a smooth performance increase once completed because over time these things get dirty and are less efficient.
    Running a fuel injector cleaner over few oil changes can help as well.
  14. Mar 23, 2015 at 1:56 PM
    #54
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    Cant see myself using anything other than 87, but they only have 87,89,93 here in SE Louisiana. I'd like to try a tank of 91, just to see what all the fuss is about.
  15. Mar 23, 2015 at 3:23 PM
    #55
    KenLyns
    Belly of the Beast
    The manual says pinging under load is OK. Unlikely the dealer will do anything.
  16. Mar 23, 2015 at 3:29 PM
    #56
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    There is the reflash for the 12+'s for pinging.
    Never used anything but good ole 87 10% ethanol.... considering you cant get ANY gas here thats ethanol free here in so cal....
  17. Mar 23, 2015 at 5:02 PM
    #57
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If that were true that would mean ethanol is a filler and has no heat value when in fact it does case in point it is burned in race cars. If you figure the lower heat value of ethanol (around 60%) and the 10% blend factor the worst case would be about a 3% loss per tank full.
  18. Mar 23, 2015 at 5:13 PM
    #58
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
  19. Mar 23, 2015 at 5:20 PM
    #59
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    might just be mental. When I switched from Mobil1 to Penzoil Ultra I was certain the vehicle ran better, quiter and smoother. Might of just been fresh oil.
  20. Mar 23, 2015 at 5:53 PM
    #60
    OZ-T
    Peter North
    British Columbia
