87 vs. 89 vs. 91 Octain fuel. My findings....
Discussion in 'Performance and Tuning' started by chris4x4, Sep 23, 2008.
  1. Sep 23, 2008 at 9:34 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Over the summer I have been testing to see the "real world" difference between the 3 grades of fuel. My tests were done on a 155 mile loop from an elevation of 1080 ' up to 5500' and back. Average speed was targeted at 68 mph. Up hills I maintained 80-90. down hills I maintained 70. Temps for all three tests was 105*. Hills ranged from gradual to 6.5%. During this loop, the truck was being pushed pretty good, as anyone in AZ who has driven up north can attest to the amount of hills and twisty roads.
    87 octain yeilded 15.12 m.p.g.
    89 octain yeilded 15.51 m.p.g.
    91 octain yeilded 16.61 m.p.g. *
    *note: On the 91 oct. test, I was loaded with 200 lbs. more stuff than the other 2 tests, and still received better mpg.
  2. Sep 23, 2008 at 9:35 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    That's some good info, chris!
    Thanks for doing the legwork!
  3. Sep 28, 2008 at 9:17 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    but how much more did you pay per gallon of 91? the mpg may not make up for the initial investment in $ per miles lol
  4. Sep 28, 2008 at 9:39 PM
    VeeRFour05
    VeeRFour05 Active Member
    Well for the 155 mile trip assuming a difference of 20 cents per gallon between 87 and 91, you'd save about $2. I personally have never noticed a difference in my cars. Shouldn't make too much of a difference, only difference is a higher flash point on the 91.
  5. Sep 28, 2008 at 11:56 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
    What's the cost factor broken down into your findings?
  6. Sep 29, 2008 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right! there is a $0.20 difference between 8 and 91. I feel much more performance between the grades of gas. For example, when accelerating onto a freeway, when the truck would shift, there would be a degree of ping. With the 91, there is no ping, and the truck has a noticable "jump" off the line, and thru the rpm range. As 91 is "recomended" in my owners manual, and the truck runs notica bly better, I will continue to run it. Hell, a 2$ saveings aint bad!
  7. Sep 29, 2008 at 6:19 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Do you have 93 stuff over there in AZ?
    I think the gas here in Texas is 87 91 93.
    I use the 91 stuff ever since I noticed a better performance from 87.
  8. Sep 29, 2008 at 6:22 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    what about pure racing fuel. could that be good or bad. i know that there could be a possibilty of burning the o2 sensors out and all but still...
  9. Sep 29, 2008 at 6:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No 93. My only other options are 95, 100, 102, 105, and 110. Those are much more ecpensive and not easilly gotten.
  10. Sep 29, 2008 at 6:25 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I run premium. I can feel a difference in how my truck drives, and I usually get 1MPG more than I do with regular. For me, its worth the extra cost.
  11. Sep 29, 2008 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Never tried it on this Tacoma. I used it on my 2000 when I was super charged, and it was AWSOME!
  12. Sep 29, 2008 at 6:56 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    You guys KNOW how I feel on this=thats why I say 91 ALL THE WAY :D:D Screw that 87 crap!
  13. Sep 29, 2008 at 7:52 PM
    bambooshoots
    Kevin
    College Station, TX
    Now, that's only for engines that can make something out of 91.
    If you put 91 in an engine that recommends 87, I doubt you'd get anything extra out of it.
  14. Sep 29, 2008 at 8:23 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    R ight you are:)
  15. Sep 30, 2008 at 12:22 AM
    Janster
    Jandy
    Lancaster, PA
    How'd you figure $2.00?
    What's all that break out to be in cost per mile for both?
  16. Sep 30, 2008 at 6:24 AM
    bambooshoots
    Kevin
    College Station, TX
    Let's say Plus is about 15 cents more than Regular. It's more like 10-12 cents more here in Texas, but lets use 15 cents for the nationwide average.
    A fill up of 20 gallons would be 20gal * $0.15 = $3.00 more if you use Plus, or also $3.00 saved if you use Regular over Plus.
    Let's say that using Plus gets you 1.5mpg more than regular. Could be as low as 1, could be higher.
    So, 1.5mpg * 20gal = 30 miles more per tank. Most of us get ~18mpg, mixed driving (don't kid yourself with lifted with heavy off road tires).
    So 30mi/18mpg = 1.667 gallons worth of "extra" gas if we had used plus. Well, currently gas averages $3.65 (Reg) nationally, so 3.65 * 1.667 = $6.09 more than would have to been spent using Regular to travel as far as when using Plus. So, $6.09 - $3.00 saved earlier when using Regular = $3.09 saved when using Plus.
  17. Sep 30, 2008 at 6:37 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    That's terrible MPG!! 80-90 mph up hills.. must be those AZ money trees?
  18. Sep 30, 2008 at 7:10 AM
    Janster
    Jandy
    Lancaster, PA
    I looked at it a different way....
    Using Chris's original figures of 20cents more (per say) for 91 versus 87.
    87 Costs $4 a gallon (for example) He's getting 15.5mpg. That's $.2581 cents per mile.
    91 Costs $4.20 a gallon. He's getting 16.6mpg. That's $.2530 cents per mile.
    We'll say you're getting 350 miles per tank - which leaves you with a total cost of:
    $90.335 for 87 for 350 miles
    $88.55 for 91 for 350 miles
    That's only $1.79 savings for 350 miles.
    If you drop the gas price to $3.50 & $3.65 - then the difference is only $2.06 per 350 miles.
    The cost per mile will probably vary a lot between one truck to the other and how we drive etc. You'd probably have to run your own tests to see how your own results end up.
  19. Sep 30, 2008 at 8:39 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    91 octane (that is 100% pure gas here in WI) that has the +1 mpg advantage over 87 10% ethenol and with the added benefit of cleaner engine if your keeping the truck well into its later years could be argued as the way to go indeed! :)
    After my intake install this week, I will try to get some results with 87 - 90 % gas vs. 91 - 100% gas
  20. Sep 30, 2008 at 8:43 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I just realized that two fillups ago I used 89 and then at my last fillup I calculated my gas mileage. I normally get 21.3 mpg, but with the 89 I only got 20.3 mpg.
