87 vs. 89 vs. 91 Octain fuel. My findings....
Discussion in 'Performance and Tuning' started by chris4x4, Sep 23, 2008.
  1. Sep 30, 2008 at 9:04 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    So not only does the truck run better on 91 it also cost less. I suspect this would be true on many cars and trucks. However, most people have bought the standard line (mainly from the media) that 91 is a waist of money. Also, most people don’t have the minimal math skills to figure it out for themselves.
  2. Sep 30, 2008 at 9:16 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    But - how many people can say they actually improved their gas mileage and by what extent?
    It's a similar situation with buying aftermarket air filters or even exhaust - that you'll increase mpg. It doesn't always work for everyone. You have to experiment for yourself.....
  3. Sep 30, 2008 at 11:18 AM
    CometKat
    Carson City NV
    You have to have a certain mechanical sensitivity to notice the difference in performance between 87 and 91. So all the people that spend their car time listening to their stereo on volume 11, or blabbing on their cell phone, or texting nonsense to their friends, will not notice. On cost, even if it was a wash it is still worth filling up with 91 because of this performance advantage. I did my own experiment and 91 is worth an extra 2mpg - more than enough to offset the extra cost at fill-up.
  4. Sep 30, 2008 at 6:37 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Thank You! :)
  5. Sep 30, 2008 at 6:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It is bad mpg. However, to put into perspective, My '04 Dodge Dakota with 4.7, 4x4, quad cab, did the same run in the same time, and got 11.8 mpg. Its a mpg loop that my Dad and I have mapped out that seems to give very repeatable results, which is what I was after.
  6. Sep 30, 2008 at 7:18 PM
    Janster
    Jandy
    Lancaster, PA
    The 4.7L is a V8....isn't it? Never heard of Dodge making a 4.7L V6.
    So - you're comparing the gas mileage of a V6 to a V8.
    But yeah, I agree with some...your gas mileage sounds low. What kind of terrain is the Loop you speak of? I haven't got anything less than 18mpg in my truck since I got it.
  7. Sep 30, 2008 at 7:48 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Jan-you drive a VETTE!! Hence the skepticism. What is that baby, like 345HP?? :D
    I jumped in here at this point cause, aside from the mileage improvements meticulously studied by Chris, I myself get only 91 octain because with it my engine runs at optimal timing advance-hence max power. With lesser octain those knock sensors tell the ECU to retard the timing to eliminate ping=power loss. I swear to you here Jan-I have not heard ONE ping ever utter from ths motor its whole life! Thats why I like it.
    You are obviously content with your truck on 87-those sensors do a great job...AND your V6 has more than adequate power so the loos over octain is moot.
    But like I said in another thread on this, with lower octain, your knock sensors retard timing=power loss-and with that power loss comes a natural tendency to increase the throttle to achieve a value of power=slight mileage loss overall. THAT is where the mileage thing is rooted:)
  8. Sep 30, 2008 at 8:09 PM
    Janster
    Jandy
    Lancaster, PA
    I'm not againest running 91....I might try it sometime. But the small benefits chris is seeing - might not pertain to everyone based on driving habits, driving conditions, & many other variances.
    Chris was comparing his v6 gas mileage to a V8.... and a Dodge V8 at that. His gas mileage does seem a bit low.
    As for the vette - it gets better gas mileage than anything else in the family. It requires 93 octane and we got 32mpg going to Virginia in it. The 6 speed is geared so low that it cruises along at 70mph at 1500rpms. Why couldn't toyota do that with a v6?
  9. Sep 30, 2008 at 8:11 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I wish it wasn't true but I have just last night got 15.98 mpg. Seems my mileage is dropping.
  10. Sep 30, 2008 at 8:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, I wasnt really comparing them, just throwing out what really bad milage was. And, yes. Im well aware that the 4.7 is a V8. :rolleyes: My whole point of this test is that it is a loop that yeilds repeatable results. Its a hard loop, with a 4500' + elevation gain. 6%+ grades,. and maintaining 68 mph keeps the engine working. I was simply trying to give my findings of 87/89/91 octain fules. FWIW, I get 20 mpg on a regular basis in town. But you cant test "In town" as there are always many variables. Stop lights, traffic, etc. Therefore, you dont get as accurate of results.
  11. Sep 30, 2008 at 8:18 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Wow talk aout having the best of everything in a vehicle-AND your vintage of Vette is the best of all the later styles including the new ones IMO
    As far as why Toyota couldn't do a 6-speed-I'm thinking it's because the Vete has way ample low end torque and power-to-weight ratio that the truck dont:)
  12. Sep 30, 2008 at 8:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ANd aerodynamics......a vette has HALF the frontal area of a truck.
  13. Sep 30, 2008 at 8:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No, Janster. Follow the bouncing ball........I was comparing 87/89/91 octain fuel. The Dodge V8 mpg was thrown in for ilistration.
  14. Oct 1, 2008 at 2:17 AM
    Janster
    Jandy
    Lancaster, PA
    Well, there's your problem right there!!
    Slow 'r down and run the tests again. :thumbsup:
  15. Oct 1, 2008 at 10:21 AM
    #35
    CometKat
    Carson City NV
    I think this whole discussion is a little over your head.
  16. Oct 1, 2008 at 10:32 AM
    #36
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    The slower burn of 91 just might take away power. I have a V-Rod & my neighbor has a V-Max. When we go out riding he must find a Citco with 104 or 110, I just shake my head and smile.:D
  17. Oct 1, 2008 at 12:18 PM
    #37
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i agree 100%! i always drive with the radio turned down to hear my engine and make sure i have no leaks. the pinging is also noticeable when using lower grade octane
  18. Oct 1, 2008 at 1:49 PM
    #38
    Mr.Ed
    Wilbur's Barn
    When I purchased my Tacoma the dealer said 87 octane. I use 89, the compression ratio 10.0:1 so I thought 87 was low. If the temp is 105 & your towing, 87 octane must sounds like detonation city. Does the computer retard the timing if it starts knocking? What octane does Toyota recommend? Also is it a RON or MON rating? :cool:
  19. Oct 1, 2008 at 1:50 PM
    #39
    tacoskim
    Los Angeles, CA
    Stock
    87 is what toyota recommends
  20. Oct 1, 2008 at 1:58 PM
    #40
    Mr.Ed
    Wilbur's Barn
    That seems low for 10:1 compression, I had read on a thread the 4.0 has a Hemi type head. That might be why we can get away using 87.
