87 vs. 89 vs. 91 Octain fuel. My findings....
Discussion in 'Performance and Tuning' started by chris4x4, Sep 23, 2008.
  1. Oct 1, 2008 at 4:42 PM
    #41
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Interesting. I have hear this from others. My owners manual says "....recomend 91 octain or higher for best performance....."
    Most overhead cam motors this day have an hemispherical combustion chamber. The Tacoma uses a pretty sofisticated way of controling engine knock. First, it employs sxensors in the block to detect the "ping". Then, it controls the preignition by enrichening the mixture, and backing off the timeing. The better the programming, the higher the compression ratio can be, all things being equal and to a certain degree. :)
  2. Oct 1, 2008 at 7:30 PM
    #42
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    WTF?
    I was referring to chris's gas mileage which seams a bit on the low side. If he wasn't going 68mph - he might see better mpg.
  3. Oct 2, 2008 at 7:01 AM
    #43
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Among other things Chris never said his gas mileage was a problem and 68mph was a target speed for consistency on the mileage test loop. So you are making references to points that were not made.
  4. Oct 2, 2008 at 7:16 AM
    #44
    Janster
    Jandy
    Lancaster, PA
    Have you been following the posts?
    It was MY OPPINION that his gas mileage was a bit low. I'm not the only person who commented on that. Chris explained why.... I understand.
    But when he said he's going 68mph - I simply said...."There's your problem! Slow it down and run the tests again!!" Perhaps he'd get even better mileage if he went slower??? I'd personally be curious to see what kind of results he'd get going slower.
    Chill out....I think you got lost in the flow of things there a bit. Sorry...but it wasn't meant to be taken all serious-like. Chris already knows I'm a putz. (hehehe)
  5. Oct 2, 2008 at 7:34 AM
    #45
    CometKat
    Carson City NV
    My case in point!
    He is not trying to improve his gas mileage. He is simply comparing the different grades on a consistent loop.
  6. Oct 2, 2008 at 7:38 AM
    #46
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    geez...I know it is a bit early to have a drink, but maybe y'all should have a drink and relax...
  7. Oct 2, 2008 at 7:46 AM
    #47
    Janster
    Jandy
    Lancaster, PA
    Hellooooo?? Anybody home?
    You're still not telling me anything that I didn't already know.
    Isocoee - I'll drink a few for ya..how's that? I just got off work and it's time for bed. :D Good night!
  8. Oct 2, 2008 at 7:52 AM
    #48
    CometKat
    Carson City NV
    Yes, get a good nights sleep and then think about it.:rolleyes:
  9. Oct 2, 2008 at 7:59 AM
    #49
    Janster
    Jandy
    Lancaster, PA
    What were you saying? Explain it to me again....
  10. Oct 2, 2008 at 8:01 AM
    #50
    CometKat
    Carson City NV
    We are just exercising our rights to be "One big happy dysfunctional family":)
  11. Oct 2, 2008 at 8:11 AM
    #51
    Hotdog
    Hotdog
    Wet Okole Underwear
    everyone knows that alcohol adds to the dysfunction :rolleyes:
  12. Oct 2, 2008 at 8:18 AM
    #52
    Janster
    Jandy
    Lancaster, PA
    ....and you're the one who suggested us all have a drink!!
    So you're the blame for it all! :D
  13. Oct 2, 2008 at 3:03 PM
    #53
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    yup the sh*t in here starts at the top:D
  14. Oct 2, 2008 at 3:27 PM
    #54
    CometKat
    Carson City NV
    Maybe if Chris ran Vodka in his tank he could get 20mpg on his test loop!
  15. Jan 6, 2011 at 7:41 AM
    #55
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Looks like a good attempt at controlling variables. I'd be interested in the same test if it were controlled for weather conditions and more importantly if it were 'double blind;' that is, if the driver did not know what gas was in the tank. It is amazing what we do unconsciously or otherwise when we want certain outcomes. And good scientists are aware that all too often they want certain outcomes even though they know they should try to be objective. That's one of the reasons for double blind studies.
    Everything I read from 'reliable' sources refers to the 'octane myth.'
    From Suffolk County, NY:
    "....The advertising claims for these various grades would have us believe that the higher the octane of the gasoline that you use in your car, the better your car will run...more efficiently, cleaner, and with more "power." These are tempting claims.
    ....Octane ratings are a measure of a gasoline's ability to resist engine knock. "Knocking" or "pinging" in an engine results from an uneven burning of the fuel-air mixture. If your car is not "knocking," using a higher octane fuel will do absolutely nothing for you but waste your money. The fact is that regular unleaded gasoline, 87 octane, is the recommended fuel for most vehicles. You can determine what fuel is recommended for your vehicle by checking your owner's manual.
    If you are using gasoline with an octane rating greater than 87 and your engine is not "knocking," drop down to a lower octane gasoline. If your engine begins to "knock," go back up to the next octane level. Remember, octane is nothing more than a measure of anti-knock quality...use the lowest octane fuel which provides you with knock-free operation.
    Another myth is that use of a high octane fuel will improve fuel economy. The fact is that fuel economy is determined by a number of variables, including the energy content of the fuel and the condition of your vehicle, neither one of which have anything to do with the octane level of the fuel. In fact, two fuels of identical octane could have different energy content due to a difference in composition.
    From the State of Minnesota's Dept of Commerce:
    "• If your engine runs well and does not knock or ping on low octane gasoline, there is no advantage in
    switching to higher octane gasoline.
    • If your engine knocks or pings, it does not necessarily mean something is wrong with the gasoline. It could
    be a problem with the engine’s electronic control systems, ignition timing or exhaust gas recirculation. On a
    high mileage engine, a carbon build-up in the cylinders can increase cylinder pressures and cause knock.• Almost all of today’s new cars have fuel-injected engines that need to use gasoline with a detergent additive.
    They do not necessarily need high octane gasoline with a detergent additive. Generally, new automobiles
    need high octane gasoline only if the manufacturer recommends it.
    • Always follow the auto manufacturer’s octane recommendations in your owner’s manual.
    Octane Myths
    • High octane gasoline improves mileage.
    In general, if your car is designed to run on 87 octane gasoline, high octane gasoline will not improve
    mileage. If switching to high octane gasoline does improve mileage, you might find that your engine, or its
    control systems, need repair.
    • High octane gasoline gives quicker starting.
    No, it doesn’t.
    • High octane gasoline increases power.
    If your car is designed to run on 87 octane gasoline, you shouldn’t notice any more power on high octane
    gasoline. Again, if it does make a noticeable difference, your engine, or the engine’s electronic control
    systems, may need repair.
    • High octane gasoline has been refined more – it is just a better product.
    Additional refining steps are used to increase the octane; however, these additional steps do not necessarily
    make the gasoline a “better” product for all engines. They just yield a different blend of hydrocarbons that
    burn more slowly. The additional steps also increase the price."
  16. Jan 6, 2011 at 11:00 AM
    #56
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks for the input Dan. As for the temps, I noted in the first post, that the temps were the same for all tests, within 1* or so. As for the barometric pressure, Im sure it differed time to time, but I dont think it waried much to note. The weather out here in the summer time is pretty consistant. And as for a double blind test, I thought about that too, but wasnt sure how to go about it. Another thing to point out, My truck did have predetonation under 3/4 throttle when using the 87 oct. fuel. I didnt notice it on the 89, or 91, but after I did this test, I switched back to the 87 and found the detonation came back, and performance suffered a little bit.
  17. Jan 6, 2011 at 11:14 AM
    #57
    walleyeguy
    walleyeguy Well-Known Member
    '12 4x4 DCSB TRD OR Auto MGM
    Was the different grades of gas used all with some and the same amount of ethanol?
    In my area 87 & 89 octane contain up to 10% ethanol, however 91 octane does not have ethanol. Ethanol has a lower energy content, 70% the amount of energy as regular gasoline.
  18. Jan 6, 2011 at 11:15 AM
    #58
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I bought the different grades from the same station, and the same pump.
  19. Jan 6, 2011 at 11:52 AM
    #59
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    I'm a believer in 91! Shoot me...
  20. Jan 6, 2011 at 7:59 PM
    #60
    Ridgerunner
    Frank
    Rocklin, Ca.
    yeah me too. 91 naysayers don't get that 91 burns better than 87-and if ya don't get knock with 87 it's due to the computer retarding your timing to null it, resulting in less power and more throttle input. The increased 91 price per gallon is justified and negated via better burning. I have been running 91 in my truck its whole life. Not one single ping or knock out of that motor.
