87 vs. 89 vs. 91 Octain fuel. My findings....
Discussion in 'Performance and Tuning' started by chris4x4, Sep 23, 2008.
  1. Jan 6, 2011 at 8:28 PM
    #61
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    That you know of....
    you can have detonation that isnt audible to the human ear.
    I always run 91..even before I was boosted. E85 is next
  2. Jan 6, 2011 at 8:48 PM
    #62
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    yeah semantics but you're right. It's the audible ones that kill.
  3. Jan 6, 2011 at 9:01 PM
    #63
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Interesting Chris. I have to admit that despite my bias based on octane ratings (as posted); if I had the experience you relate, I'd use higher octane fuel, . . . or inquire about whether there is some other reason my truck did not operate well on 87.
  4. Jan 6, 2011 at 9:08 PM
    #64
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    And the next time they say that fuel does not make a difference; just keep this in the back of your head. NASCAR and NHRA don't use street fuel to make their horsepower, neither do War Birds. The Drag Racers use Nitro Methanol, and NASCAR uses 120 Octain Nitro Alcohol Blended Gasoline, (Racing Fuel). As for the War Birds, well they use an Avaiation Gasoline called AvGas 100LL, (100 Octain Low Lead). Pretty good for a 5000 Horsepower Dragster, don't you think?
    Take care
    vbibi:(
  5. Jan 7, 2011 at 5:52 AM
    #65
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    I don't think anyone is suggesting 'that fuel does not make a difference. The two hydrocarbons of most significance for gasoline are heptane, which has seven carbon atoms, and octane, which has eight. The octane rating is significant because octane can withstand much higher compression than heptane, and it's the high compression that increases power.
  6. Jan 7, 2011 at 7:22 AM
    #66
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    And the 1GR-FE has a 10-1 comp ratio. Thats considered "High compression" as far as these engines go.
  7. Jan 7, 2011 at 8:09 AM
    #67
    Ridgerunner
    Frank
    Rocklin, Ca.
    I believe the 3.4 in mine is 9.6 to 1 which is in the high compression ballpark too:)
  8. Jan 7, 2011 at 9:02 AM
    #68
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    You cannot fairly compare compression ratios for older, carburetted engines without engine management systems ] with newer ones. For example, from http://www.faqs.org/faqs/autos/gasoline-faq/part3/
    "For a typical carburetted engine,
    without engine management [27,38]:-
    Compression Octane Number Brake Thermal Efficiency
    Ratio Requirement ( Full Throttle )
    5:1 72 -
    6:1 81 25 %
    7:1 87 28 %
    8:1 92 30 %
    9:1 96 32 %
    10:1 100 33 %
    11:1 104 34 %
    12:1 108 35 %
    Modern engines have improved significantly on this...."
    The current 4 cyl. Toyota has a compression ratio of 9.6:1, yet only requires 87, not 98 as the chart above would indicate. The entire article ref'd above is illuminating, but I'll paste just one more selection:
    "If you use a fuel with an
    octane rating higher than what the engine can use, you are just wasting
    money by paying for octane that you can not utilise. The additive packages
    are matched to the engines using the fuel, for example intake valve deposit
    control additive concentrations may be increased in the premium octane grade.
    If your vehicle does not have a knock sensor, then using a fuel with an
    octane rating significantly below the octane requirement of the engine means
    that the little men with hammers will gleefully pummel your engine to pieces.
    You should initially be guided by the vehicle manufacturer's recommendations,
    however you can experiment, as the variations in vehicle tolerances can
    mean that Octane Number Requirement for a given vehicle model can range
    over 6 Octane Numbers. Caution should be used, and remember to compensate
    if the conditions change, such as carrying more people or driving in
    different ambient conditions. You can often reduce the octane of the fuel
    you use in winter because the temperature decrease and possible humidity
    changes may significantly reduce the octane requirement of the engine.
    Use the octane that provides cost-effective driveability and performance,
    using anything more is waste of money, and anything less could result in
    an unscheduled, expensive visit to your mechanic."
  9. Jan 7, 2011 at 9:32 AM
    #69
    Ridgerunner
    Frank
    Rocklin, Ca.
    Bottom line is you can run 87 if you want-the ECU will retard the timing according to the detonation it detects, then yeah there won't be any knock but you'll give up some power and FUEL EFFICIENCY. I'll take 91-thank you:)
