87 vs 91
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nd, Mar 22, 2007.
  1. Nov 24, 2016 at 10:37 AM
    Lthompson
    Lthompson Well-Known Member
    High octane only makes a difference when it is needed because of high compression, high cylinder pressures, and high heat.. But if lower octane is causing detonation, and knock retard.. Then you need to go higher. If a vehicle can run just fine with no issues at all on 87, then running 91+ is pretty much pointless. But any issues at all is the key. Slightest detonation can beat up your pistons and combustion chambers and valves in a hurry.
  2. Nov 24, 2016 at 10:40 AM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I have a 2005 with the 4.0. In my owners manual it recommends 87 octane. Most of the gas stations in the area have 87 as Regular gas except for they have 88. If I am filling cans for my 4 wheelers I use the supreme which is 90 and I will fill the truck with that and I have noticed the truck doesn't get as good of mileage.
  3. Nov 24, 2016 at 10:44 AM
    Pigpen
    Dan
    Northwest Montana
    I run premium in my chainsaws. On the rare occasion when trying premium in my Tacoma I got slightly worse mpg and paid an extra $.40 per gallon.
  4. Nov 24, 2016 at 12:31 PM
    Lthompson
    ive still bout half a tank of 93 left, I'm gonna mix it with 87 or 89 and see what happens.
  5. Nov 24, 2016 at 1:16 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    These threads man.... :deadhorse:
  6. Nov 24, 2016 at 3:51 PM
    Pigpen
    Dan
    Northwest Montana
    :rofl:
