881's and 3 leaf mini pkg lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Aug 30, 2010.
  1. Aug 30, 2010 at 4:42 PM
    twfsa
    twfsa [OP] Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    [​IMG] Bilstiens set to Zero
  2. Aug 30, 2010 at 5:05 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Wow man that looks great. I don't know why alot of people skip the 3 leaf progressive AAL - its cheaper and preserves ride quality.
    Any driveline vibrations with the lift?
  3. Aug 31, 2010 at 6:12 AM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    I haven't noticed any vibration, I still need to raise the BPV, I have some scrap in the garage to fab one just need to get a few other things around the house done.
  4. Aug 31, 2010 at 6:19 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    They didn't give you one with the kit?
    Thats pretty much the exact kit that I went with. Did you keep the stock shocks in the front and what shocks did you go with in the rear? I went with the pro comps.
    Trying to figure out if I can stuff 285/75's in there.
  5. Aug 31, 2010 at 1:43 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    No bracket for the BPV in the mini leaf pkg, that kit is kinda a bitch to install at least on the driver side I had to use 2 floor jacks, one suporting the pumpkin, the other lifting the disassembled leaf spring, raiseing it up so I could get that center bolt in the leaf spring once I had all the leafs positioned. 5100's all the way around.
  6. Aug 31, 2010 at 2:43 PM
    kyle39
    kyle39 Reppin' BC
    Kyle
    Vancouver BC
    04 Tacoma Trd
    Deck plate mod, rhino lined, A.r.e. flush glass shell, 265/75/16 Duratrac's, MB72 rims, Full OME lift, Dakars in the rear, Tint allround
    looks good, what size tire you currenty have? thinking bout doin that to mine:cool:
  7. Aug 31, 2010 at 2:55 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    When I was looking into AAL's, the guy at Wheelers told me the 3 leaf actually cut down on load capacity since it removed the overload leaf. If you don't care about that, from what I understand the 3 leaf can give better ride quality than adding a single AAL.
    Either way, your truck looks good!
  8. Aug 31, 2010 at 4:31 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    265/70/16
