883's lifted my truck almost 2 inches! WTF?
Discussion in 'Suspension' started by helidave, Oct 27, 2013.
  1. Oct 27, 2013 at 12:09 PM
    helidave
    helidave [OP] Well-Known Member
    phoenix
    '10 DCSB TRD Prerunner
    I wanted to level my truck so yesterday I installed 5100's and 883's. The 5100's are at the lowest setting and the 883's are advertised as 1.25-1.5" lift. I didn't go with 884's because I didn't want to lift the rear, but now my truck is slightly nose high.
    Are they going to settle?
  2. Oct 27, 2013 at 12:12 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    if the 5100's are at the lowest setting-->stock, then you should be at that setting. Is it possible that a. the 5100's are set at something different, b. you didn't get 883 coils, maybe a heavier coil, or c. your suspension was so sagged out that 1.5 inch over stock maybe been 3inch on a sagged out suspension?
    Edit:if they are the OME x springs they wont settle a whole lot.
    Edit: I misread the title, thought it said 3 inchs out of the lift. .5 and inch isn't huge, you may have just gotten a little sagging in your older suspension and actually gained 2 inch over your old suspension, but only 1.5" over stock.
  3. Oct 27, 2013 at 12:14 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    yes
  4. Oct 27, 2013 at 12:18 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    You just installed yesterday they will probably settle a little. What does is measure from the center of you hub to the bottom of your fender flare? Like others said your rear end has probably sagged a good amount over time. Go wheeling and flex out your front suspension :D you also have a prerunner, so the front end weighs less than a 4x4, so you might sit higher than others.
  5. Oct 27, 2013 at 12:21 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^That. Did you just drop the truck down off the jack and measure? Or did you take it for a spin around the block to settle the suspension?
  6. Oct 27, 2013 at 12:21 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    They are brand new they should settle 1/2" to 1".
  7. Oct 27, 2013 at 12:42 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Again, if they're the 883X's they'll be scragged and won't settle much at all.
  8. Oct 27, 2013 at 1:26 PM
    helidave
    phoenix
    They are the X's. The truck only has 27000 miles on it, I doubt the stock suspension was that worn out. I measured after driving 20 miles or so.
  9. Oct 27, 2013 at 2:04 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    I would give it at least a week before buying a AAL or something to lift the back. My 885x's have settled about 3/4" of an inch, but i added extra weight to the truck. The did settle a little bit initially.
  10. Oct 27, 2013 at 2:05 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    I thought these numbers were for 4 door 4x4s?
  11. Oct 27, 2013 at 2:22 PM
    helidave
    phoenix
    from Wheeler's site: "These could give you approx 1.25″ to 1.5″ lift on a stock Tacoma, depending on chassis."
  12. Oct 27, 2013 at 2:24 PM
    95 taco
    95 taco Battle Born
    forgot you were a 2nd gen, sorry.
  13. Oct 27, 2013 at 2:32 PM
    nfs257
    DFW
    She gone
    Did you get an alignment? If not the numbers are false...
  14. Oct 27, 2013 at 2:44 PM
    helidave
    phoenix
    Yes. Caster 1.8, Toe 0.05, Camber 0.9. I'm going to have it re done at a more reputable shop, but first I need to figure out if Im going to lift the rear.
  15. Oct 27, 2013 at 2:47 PM
    nfs257
    DFW
    She gone
    lifting the rear will not affect your front alignment.
  16. Oct 27, 2013 at 5:27 PM
    helidave
    phoenix
    It will affect caster.
  17. Oct 27, 2013 at 8:44 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    ^ yeah this is true unfortunately, anytime you mess with the rear it does throw off the front too.
    OP - brand new coils will settle a ton from the time you set the truck back down. go hit some speed bumps roll up slow but let the truck come down the backside hard to bounce the front end as much as possible and it should settle. A couple of weeks ago we put a 2" leveling kit on my neighbors 11' 4Runner and it resulted in a solid 4" lift right off the jack... Rolled some speed bumps and it settled 2".
