884/885 for a 2nd gen double cab
Discussion in 'Suspension' started by elwood, Feb 17, 2011.
  1. Feb 17, 2011 at 5:46 PM
    elwood
    elwood [OP] "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Ya I know another one, but I am looking for anybody who has put an 884 in a double cab RECENTLY and what results they achieved. Chris has helped HUGE and I am close to pulling the trigger on this but am hoping for some results pics.
    My intentions-- 2 inch for the front and the 1.5 tsb aal for the rear/ OME shocks X 4 ---keep stock tires. KEEP rake.
    I have looked at the 5100 eibach set up and still kind of like the OME stuff/ no offence.:eek:
    Want to do this right and only once.
    Lift has been ordered/ post 42
    ***************************New thread for the installation and comments.......... http://www.tacomaworld.com/forum/showthread.php?t=149572
  2. Feb 17, 2011 at 6:17 PM
    Tythias
    Tythias Active Member
    Yes, I would also like to know about the 884 coils and possibly the 883s.
    I have heard they have changed them over the years and would like to know more recent lift results as well.
    From what I have found (These are approximate lift amounts)
    885 = 3"
    884 = 2"
    883 = 1"
  3. Feb 17, 2011 at 6:28 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Why do you only want 2" of lift? Save some money and go with 5100s IMO. Are you looking to improve your ride, because that coil was not desgned to handle weight of double cab.
  4. Feb 17, 2011 at 6:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 884 is fine on a double cab. Its the same rate as the 885, just 10mm shorter in length.
  5. Feb 17, 2011 at 6:39 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Oh well hell....once again chris knows more than me.
  6. Feb 17, 2011 at 7:34 PM
    Tythias
    The 883 is also the same rate as the 884 and 885 just shorter in length than the 884
  7. Feb 17, 2011 at 8:24 PM
    225nontypical
    225nontypical ????????????
    backwoods
    11 tundra DC TRD OffRoad
    bilstein 5100's weather tech floor mats katskinz leather heated seats
    So if you want 3 inches of lift and you buy the 885's do you need a top plate spacer?
  8. Feb 17, 2011 at 8:32 PM
    NLF
    NLF Well-Known Member
    Levi
    Minneapolis, MN
    '11 TRD Sport DC LB 4x4
    OME 884 & Bilstein 5100s @ 0, TSB Rear w/5100s, 20x8 Mamba M2 275/55/20 Geolander, Access Cover
    884s will be here monday for my dc lb. Will post pics once installed.
  9. Feb 17, 2011 at 8:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats hit or miss. Some are getting the full 3", while others are getting a little less. I would say get the top plate spacers, but only install them if the 3" lift isnt achieved.
  10. Feb 17, 2011 at 9:36 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This is the route I'm going ^^^
  11. Feb 17, 2011 at 9:46 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'm running 885s and i'm getting a little over 3". No top plates, just the 1/4" driver side top plate to fix the Taco Lean
  12. Feb 17, 2011 at 9:49 PM
    OZ-T
    Peter North
    British Columbia
  13. Feb 17, 2011 at 10:06 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Before I got my front bumper, I had 884s, then eventually 886s. I switched to 886s because the 884s had sagged dramatically. It started to rub in places that it didn't rub before (33" tires), even after trimming.
    I bought the 886s with no intentions of getting a front bumper. In fact, I had the 886s a long time before getting the front bumper. Honestly, I didn't notice any kind of difference in stiffness between the 884s and 886s. 884s and OEM coils? yes there was a difference but not when I upgraded to 886s.
    884 (with top plate spacer) pics
    886 (with top plate spacer, eventually taken out because CV angles were shot) pics
  14. Feb 18, 2011 at 4:25 AM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    Thanks NFL for the future pics. What set up are you going for? 884's and ? shock.
    Are you taking out the 5100's???? Why?
    Thanks again Chris.
  15. Feb 18, 2011 at 6:18 AM
    NLF
    Levi
    Minneapolis, MN
    After lots of help from Chris4x4 (thanks again) I decided on the 884 with 5100 set at 0 in front, TSB rear with 1.5 Toytec AAL & 5100 in rear.
    My goal is to get around 2"-2.25" of lift in front, and then have some rake in the rear for when I haul a trailer.
  16. Feb 18, 2011 at 12:01 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    Let me know when you are done , i would really like to see some pics. I to haul and want the rake to stay.
  17. Feb 18, 2011 at 12:31 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    That sounds like a decent lift without hurting in the pocket!! I like that!!
    I personally was looking at the complete OME lift but that's just it, I've just been looking at it!!! LOL.....:D
  18. Feb 21, 2011 at 2:15 PM
    Tythias
    Anxious to hear the results!
  19. Feb 21, 2011 at 2:18 PM
    NLF
    Levi
    Minneapolis, MN
    Install Friday, will post pics afterward.
  20. Feb 21, 2011 at 4:33 PM
    elwood
    Neal
    ont, canada
    2007 SR5 4x4 LB
    Thanks for the update NFL. good luck and can't wait to see the pics
